Wow: Did Everyone Drop Off The Face Of The Earth?
35 replies to this topic
#1 skunkhome OFFLINE
skunkhome
  • 323 Thanks
  • 455 posts
Posted December 30, 2012 - 12:58 PM
Or is everyone just too full of Christmas turkey? Maybe too busy blowing snow.
What have y'all been doing with your AC/Simplicity tractors. I have been hiding inside most of the time from the foul weather but managed to finish my engine transplant in Sweet Allis, my 3414, to include a complete re-wire and new dash to accommodate an ammeter. Mounted my Johnny Bucket Jr and moved my compost pile. New 16 hp engine runs smooth and strong but I am concerned that the stator is not charging my battery. We will see in the next few weeks if it will keep up. I suppose it is the regulator as it it appears to be puttion out about 1/2 amp on DC but has full power on AC circuit. Looks like pulling the engine again is in the cards.
Family portrait:
E0AD6F63-F37C-40CB-BA24-093584F908CE-241
  • daytime dave said thank you
#2 KennyP ONLINE
  • 37,413 Thanks
  • 45,460 posts
Posted December 30, 2012 - 01:04 PM
It's been quiet, that's for sure! Glad you got it running again. Make sure your connections are good on the charging circuit.
  • skunkhome said thank you
#3 skunkhome OFFLINE
skunkhome
  • 323 Thanks
  • 455 posts
Posted December 30, 2012 - 01:18 PM
I have checked the voltage/amperage at the pigtail on the engine, so the next step would be to go behind the shroud. Don't look forward to that because I have to pull the JB harnesses to get the hood off. If I do that I will be looking at doing a modification on my grill to allow the plugs to pass through.
#4 JRJ OFFLINE
JRJ
  • 876 Thanks
  • 1,170 posts
Posted December 30, 2012 - 01:28 PM
Are you sure the battery is in good shape??
Dick
#5 daytime dave ONLINE
  • 4,782 Thanks
  • 6,522 posts
Posted December 30, 2012 - 01:35 PM
Great pair of ACs there.  Thanks for the picture.
#6 KennyP ONLINE
  • 37,413 Thanks
  • 45,460 posts
Posted December 30, 2012 - 01:36 PM
Is the regulator/rectifier on the shroud? Might be that if the AC is within limits. Or a connection there!
#7 skunkhome OFFLINE
skunkhome
  • 323 Thanks
  • 455 posts
Posted December 30, 2012 - 01:58 PM
The engine is a 326437-2527-01 and has the dual voltage pigtail and rectifier/regulator under the shroud. Battery is relatively new and strong.
4644D685-29F1-4B07-A56D-F74090F46FAA-402
It could be a connection under the shroud but either way it means pulling the engine.
Edited by skunkhome, December 30, 2012 - 02:00 PM.
#8 bigcountry48 OFFLINE
bigcountry48
  • 101 Thanks
  • 207 posts
Posted December 30, 2012 - 02:29 PM
Well down here the grass won't grow and the sun won't shine so there ain't to much to post about, lol!
#9 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted December 30, 2012 - 03:13 PM
Just got in form blading slush off the driveway with my ford. Sitting here watching John Wayne in Mc Clintock while waiting for the kids to get here for lunch. Those are some nice Ac gts, hope you get them figured out.
#10 Cvans ONLINE
  • 6,454 Thanks
  • 6,052 posts
Posted December 30, 2012 - 03:23 PM
Haven't had time to even look at the tractors for the last couple of days and probably won't until at least Tuesday afternoon at the earliest.  :(
Phil your tractor turned out very nice. They make a good looking pair.  :thumbs:
#11 A.C.T. OFFLINE
A.C.T.
    Another Classic Tractor
  • 2,364 Thanks
  • 2,496 posts
Posted December 30, 2012 - 04:48 PM
Good thinking Phil!
#12 JDBrian OFFLINE
  • 9,601 Thanks
Posted December 30, 2012 - 05:13 PM
Make sure you have a good connection from the regulator chassis back to the battery - terminal. If you have even a small amount of resistance it will prevent the charging circuit from working properly. With all newly painted tin on the engine perhaps you are not getting a good connection.
  • Cvans and skunkhome have said thanks
#13 oldedeeres ONLINE
oldedeeres
  • 9,145 Thanks
  • 4,629 posts
Posted December 30, 2012 - 06:09 PM
Don't park 'em too close together---- you never know what such a good looking pair might get up to!!   l.o.l
#14 skunkhome OFFLINE
skunkhome
  • 323 Thanks
  • 455 posts
Posted December 31, 2012 - 12:35 AM
I'll pull the negative ground running from the battery to the block and scrape the contact surface clean. That would be cool if it solves my issue.
#15 olcowhand ONLINE
  • 40,341 Thanks
  • 31,169 posts
Posted December 31, 2012 - 09:15 AM
I'm still here too Phil!  Just not done anything with my Allis 620 except to move it to get the manure spreader out of the barn.  I do need to get it in the shop over the winter to fix the right side brake.  That side has no brake action at all.  I love having steering brakes when I'm tilling, as even with the heavy 620, the front end gets light with the tiller on the back.
