* * * * * 1 votes
Who Takes Care Of Your Woodstove?
30 replies to this topic
#16 boyscout862 OFFLINE
  • 13,437 Thanks
  • 9,384 posts
Posted December 30, 2012 - 12:47 AM
Our teenage son will do it when told to but only when told to. He cuts, splits, and brings in the wood with me but, he's a typical teenager that will try to cut corners to save his precious time. He and I aren't bothered by the cold but, my wife wants it atleast 65 in the house. I'm heating with a Jotul 602 also. It works best with oak, ash or hickory. I've fit 18" sticks in diagonally when my eyeball calibration was off for the cutting.
Most of us burning wood are financially responsible. A cord of hardwood burned in a decent woodstove is equivalent to 200 gallons of heating oil. Thats about $800 these days. It also keeps the house warm when the power goes out. If you cut your own wood, it also justifies getting a big tractor.
#17 marlboro180 OFFLINE
marlboro180
  • 635 Thanks
  • 954 posts
Posted December 30, 2012 - 01:09 AM
Ryan, I cut the trees down, split it, stack it and stoke the fire myself. But then again, I use it just in my shop, not in my home  so it is my time and energy spent for my toils. :-)
#18 Michiganmobileman OFFLINE
Posted December 30, 2012 - 07:16 AM
I am the sole keeper of the fireplace fire.  Kathy helps with the cutting, stacking and splitting process but is afraid of the fireplace as it "poofed" some smoke out earlier this year while I has away from home, 20 minute mad dash back from my brother-in-laws expecting a house full of smoke, couldnt even smell it.
Most nights I am up several times anyway (will leave the details out in order not to scare you young men about getting old), and keep the fire going.  Can usually get a full work day burn if I stack it right and have good wood.  I am not real particular what I burn except no Pine, etc.  This started years ago when Dad had ten acres of mostly poplar. Burned OK dry and was there for the taking. This year I was blessed with some free Beech to burn if I went and helped with the clean up after wind blew down lots of ancient trees at the Wheatland festival grounds.  Two weekends worth of cutting and hauling and the pile next to the shed looks to get us to spring.
Sorry to hijack the thread Ryan, because we did this ourselves, and am quite proud of how it turned out, here is our stone covered fireplace, each stone chosen, cut flat on the back with a wet saw and the mortared and grouted in place.  Mantle made from a tree we cut when clearing for the house.
  • KennyP, boyscout862, marlboro180 and 1 other said thanks
#19 JDBrian OFFLINE
  • 9,642 Thanks
  • 14,157 posts
Posted December 30, 2012 - 07:43 AM
Are you going to tell them?! Cause I know that none of them would take kindly to a meeting about this! Besides, I would not be surprised if they already see that I do all of the work.
Ryan, they may not take kindly to it but leaving it as it stands will not address your concerns. By bringing it to a meeting you will at least be attempting to get acknowledgement of the issue. You then have a chance of changing attitudes and bringing on change. It may not be typical of how things work in your house but IME it could be the start of changing the way you all interact when there is an issue like this.
#20 UncleWillie ONLINE
  • 16,105 Thanks
  • 8,906 posts
Posted December 30, 2012 - 10:09 AM
Might just be time to make them all mad at you and tell them anyway. Someone has to be in charge. At my house I choose it to be me. Your mileage may vary.
Edited by mybigwarwagon, December 30, 2012 - 10:10 AM.
#21 David Brown OFFLINE
David Brown
  • 4,510 Thanks
  • 2,424 posts
Posted December 30, 2012 - 05:25 PM
I don't know your situation but, perhaps you are the only one in the family that actually likes and wants a fire?  If that's the case, I can see why nobody else would want to help.  If everybody enjoys it and wants it, then they should pitch in, even in some small way to keep it going.
#22 bh115577 OFFLINE
bh115577
  • 443 Thanks
  • 240 posts
Posted December 31, 2012 - 09:06 AM
I get a little help with stacking the firewood sometimes and once in a while I can pry the boy away from the damn xbox long enough to carry in a few arm loads of splits.
Everything else is up to me to get done as no one here wants to mess with a cat stove. Good thing is once I get it up to temp and engage the cat, it will put out good heat for 6 + hours depending on the wood I fed it with. Nothing like wood heat.
#23 Ryan313 ONLINE
  • 3,404 Thanks
  • 5,241 posts
Posted January 12, 2013 - 06:01 PM
I was just bringing in firewood, and my brother was bold enough to come into the basement to tell me I was making to much noise! Apparently, he and his friends were in his room (directly above where I keep wood) trying to play video games, I just ignored him.
After that load my back really started to hurt... and I did not want to bend over to set down the wood like I had been, so I dropped it! It just so happened that I missed the stack of wood, and the stuff I carried in had dropped all the way to the floor! Whoops! My brother did NOT like that! I told him if he did not like it, to go get his friends and do it themselves. He said it was not their nor his job to do that!
That was my last load, but being an instigator I had to keep it going after he left. I wont tell you exactly what happened, but I will give you a hint:
wood stove+ firecrackers= BIG BOOM!
He did not come down after that... does that mean I won? :D
#24 olcowhand ONLINE
  • 42,362 Thanks
  • 31,791 posts
Posted January 12, 2013 - 06:33 PM
It may mean that he is in planning stages of revenge, so........get more firecrackers!    What nerve your lazy brother has though!!!!!
#25 chris m OFFLINE
chris m
  • 3,341 Thanks
  • 4,065 posts
Posted January 12, 2013 - 06:43 PM
Glad he ain't my brother! :mad2:
I would wait till I heard him and his friends playing a game, then I would go unplug the router so they lose connection. Then just plug it back in a go about my business :D
#26 Team_Green OFFLINE
Team_Green
  • 2,214 Thanks
  • 2,305 posts
Posted January 12, 2013 - 07:01 PM
Sounds like its time for a family meeting.. Here is a direction things can go.. If you stop packing in heat will it cost your parents more to heat the house with oil or nat gas? If so would it be substantuel enough where they can afford less of the extras for your family?
#27 marlboro180 OFFLINE
marlboro180
  • 635 Thanks
  • 954 posts
Posted January 12, 2013 - 07:47 PM
More firecrackers are in order, at 4 AM....
#28 John@Reliable OFFLINE
John@Reliable
  • 1,298 Thanks
  • 1,416 posts
Posted January 12, 2013 - 07:51 PM
Not wood here but a pellet stove, usually my 15 year old son takes care of it daily. Myself,him and my oldest will carry in bags as needed.
Ryan, I agree with others about time for family meeting for all in the family, sucks feeling like your the only one who cares about it.
#29 oldedeeres ONLINE
oldedeeres
  • 10,289 Thanks
  • 5,021 posts
Posted January 12, 2013 - 07:55 PM
Here's a solution, Ryan, might involve switching to J.D.s , addoption papers, and a move about 1000 miles north, lol .  but you sound like an awfully good but unappreciated wood mover!!!     Really, talk to your folks, a familly meeting is a wonderful thing. We hope it works out for you
#30 Ryan313 ONLINE
  • 3,404 Thanks
  • 5,241 posts
Posted January 12, 2013 - 09:17 PM
Alright guys, I will take your advice and see what happens; I will let you all know how it goes. Until then, I will be stocking up on fireworks... just in case. :smilewink:
