Doing Better Now
10 replies to this topic
#1 David Brown OFFLINE
David Brown
  • 4,510 Thanks
  • 2,424 posts
Posted December 29, 2012 - 06:07 PM
I was out plowing again today since the 1-3 they were calling for turned out to be 6-8.  Anyway, someone on here along with my brother said that there may be moisture in the tank (or ice in the carb).  I believe it may have been a moisture issue.  Before I started lowing, I filled it up and added some dry gas.  A couple of hours of plowing later and the thing is running like a champ, not missing a beat.  It was fun to plow again.  I hope this does indeed fix it.  I've never had that problem before which is kind of wierd in itself I guess.  Anyway, thanks all!
  • MH81 and Dieselcubmike have said thanks
#2 olcowhand ONLINE
  • 40,365 Thanks
  • 31,175 posts
Posted December 29, 2012 - 06:10 PM
Good deal!  Doesn't take more than a drop or 2 in a fuel bowl to cause lots of grief.
  • David Brown said thank you
#3 countryboy88 OFFLINE
countryboy88
  • 100 Thanks
  • 143 posts
Posted December 29, 2012 - 08:16 PM
Glad you got it running right.  :thumbs: Hopefully that fixed it.
#4 Ryan313 OFFLINE
  • 3,364 Thanks
  • 5,230 posts
Posted December 29, 2012 - 08:25 PM
I am glad it is running better! But, can somebody explain how ice forms in the carb to me?
#5 LTD OFFLINE
LTD
    Cub Cadet Collector
  • 1,035 Thanks
  • 1,457 posts
Posted December 29, 2012 - 08:57 PM
Usually comes from condensation forming inside the fuel tank. It helps to keep the tank full or almost full.
#6 icpik OFFLINE
icpik
  • 22 Thanks
  • 40 posts
Posted December 29, 2012 - 09:22 PM
Lower pressure in the carburetor causes evaporation which takes heat.  Heat removal lowers the temperature significantly, so ice forms.  Carb icing in airplanes is a big deal, so they have carb heaters.
Don Hayes
#7 MH81 OFFLINE
Posted December 29, 2012 - 09:39 PM
Jeff, glad to hear you're back in business. For a while there, I thought we were all going to have to come down and clear your driveway out.
#8 David Brown OFFLINE
David Brown
  • 4,510 Thanks
  • 2,424 posts
Posted December 29, 2012 - 10:16 PM
Alan, you would have to do the neighbor's driveway too.  Mine can't be done without his being done.  It's a package deal.
#9 Cvans OFFLINE
  • 6,467 Thanks
  • 6,056 posts
Posted December 29, 2012 - 10:53 PM
Nice to hear that you got on top of the problem and it wasn't an expensive fix.  :thumbs:
#10 David Brown OFFLINE
David Brown
  • 4,510 Thanks
  • 2,424 posts
Posted January 01, 2013 - 03:06 PM
Well I thought I had the problem solved but I really think I have it solved now.  I had the FEL out trying to scrape some of the icy snow off the driveway.  Needless to say with no chains I couldn't do much with it.  CHAINS ARE A MUST!  They will go on tonight I hope.  Anyway I got the other PK out to clean up my mess and it quit before I got out the door.  Hmmmm.  Well I was getting fuel but no spark.  Put a new plug in and same thing.  I set out to change the coil and condensor when I noticed that the coil wire came off pretty easy.  I took a chance and pushed it back on hard.  TA DA!  Fired up and never missed a beat.  That coil wire must not have been making very good contact that whole time.  Live and learn I guess.  I just hope that is REALLY it.
#11 farmer OFFLINE
farmer
  • 9 Thanks
  • 94 posts
Posted January 02, 2013 - 01:50 PM
I had this exact same problem last summer when moving. Mine was lose at the switch
