Axle Spindles Question ?
2 replies to this topic
#1 larryd OFFLINE
larryd
  • 724 Thanks
  • 1,058 posts
Posted December 29, 2012 - 11:52 AM
I started taking my 314 apart for a repaint. Last night I took the axle off and removed the spindles. No snapring on lefft side. I don't see a snap ring in pictures in manual .  My question is shouldn't there be one . The groove is there for it.
larryd
#2 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted December 29, 2012 - 12:10 PM
Larry, the left one has the spline on it if memory serves. That one is held by the bolt that goes through the hollow between the bottom and top sections of the spindle spline when the steering linkage is attached. I have a 317 apart right now which has the identical front axle. I don't see a snap ring groove on mine. There is definitely a groove and snap ring on the other spindle.
  • larryd said thank you
#3 jd.rasentrac OFFLINE
jd.rasentrac
  • 4,804 Thanks
  • 4,302 posts
Posted December 29, 2012 - 01:27 PM
Hi Larry, maybe this will help
Attached File  314frontaxle.pdf   45.88KB   202 downloads
Edited by jd.rasentrac, December 29, 2012 - 01:31 PM.
