Hand Built Salt Or Sand Spreader
9 replies to this topic
#1 FirefyterEmt OFFLINE
FirefyterEmt
  • 451 Thanks
  • 855 posts
Posted December 28, 2012 - 12:40 PM
Hey guys, I am seriously thinking about building a sander for the back of my Massey Ferguson 12. I don't need tons of sand, maybe five to ten gallons. I would be looking at 12v power to run it to keep it simple. My plan is to keep it somewhat narrow on the depth with sloped sides. I am looking for design ideas and input at this time, so if anyone has some photos to share or thoughts, it would be appreciated!
#2 Cat385B ONLINE
    HAZMAT CAT
  • 13,778 Thanks
  • 9,918 posts
Posted December 28, 2012 - 12:55 PM
Using an older seed box from a planter would be mucho cool. About the right size, conical shaped. Just what the Dr. ordered!
I even found a Massey one for ya!
#3 Reverend Blair OFFLINE
Reverend Blair
  • 501 Thanks
  • 952 posts
Posted December 28, 2012 - 12:59 PM
An old seeder would be my first thought. I know of a guy that uses an old 8 foot seed drill (complete with discs) to sand the road into his farm, and it seems to work okay.  A spreader should work about as well.
#4 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted December 28, 2012 - 01:41 PM
I had a cheap Broadcast fertilizer spreader that  used to spread ice melt, till I dropped the dinky tires in a rut and folded up the frame and broke the  traction drive gearbox last winter.  I have kept the fiberglass hopper and am planning to make a new frame and was going to use a heater motor( that could be controlled by a rheostat (sp)to vary speed) mounted on the top side to drive the spinner.
  • JDBrian said thank you
#5 JDBrian OFFLINE
  • 9,601 Thanks
Posted December 28, 2012 - 04:50 PM
We use crusher dust rather than sand on our driveway and on the private road where I live. It's darker and causes faster melting when the sun hits it. You can get it by the cu. yd. from local landscape contractors and it's cheaper than bags of sand if you are using any great amount. You need to keep it dry though or it will freeze hard.
#6 FirefyterEmt OFFLINE
FirefyterEmt
  • 451 Thanks
  • 855 posts
Posted December 28, 2012 - 07:18 PM
Thanks guys.... I really want to build this so that it looks like a Massey built creation though.  What I need is some ideas for the drop chute, and auger set up on a store bought one. (oddly not easy from Google searching)
#7 KC9KAS ONLINE
KC9KAS
  • 5,324 Thanks
  • 4,670 posts
Posted December 28, 2012 - 07:41 PM
Sounds like a good plan....Make sure your sand is clean & dry or you will have problems.
#8 DH1 ONLINE
DH1
    Electric Tractors
  • 5,231 Thanks
  • 5,550 posts
Posted December 28, 2012 - 08:17 PM
EpoMini 20   page 3
http://epokena.com/u...ochure 2008.pdf
#9 Alc ONLINE
  • 6,740 Thanks
  • 7,395 posts
Posted January 05, 2013 - 07:47 AM
I stumbled on this today might give you some ideas , Al
http://lancaster.cra...3511038083.html
3Ea3Ke3Le5N55Kb5F4ccub556ed6e9875124e.jp
#10 Deerlope OFFLINE
Deerlope
  • 580 Thanks
  • 407 posts
Posted January 08, 2013 - 12:56 PM
I took an Epoke Mini towed type and made it over to QA to my FEL. All I want to do is sand the wheel track.
