I Am Almost Kinda Sorta On My Way To Being Ready For The Snow!
20 replies to this topic
#16 daytime dave OFFLINE
  • 4,787 Thanks
  • 6,524 posts
Posted December 27, 2012 - 11:23 PM
Sorry to hear you had trouble Ryan.  The first photograph seems to hint at that, you look pissed.  I am always wondering in the back of my head if something will go wrong when I use the beloved old iron.  I had that feeling today when the 318 pooped out.  I had just gotten out to remove snow from the top of the blower unit and it died.  I had put gas in when I started, but I did not fill it.  Boy that Onan is thirsty.  Three gallons later and I was back in business.
This ethanol gas craps up all the carbs.  I put seafoam in, but it can only do so much.  I've noticed effects on all my stuff.
At least you had a back up.  I'd like to see the set up on the ATV.  I saw an ATV with a snowblower a while back.
Edited by daytime dave, December 27, 2012 - 11:24 PM.
#17 Ryan313 ONLINE
  • 3,365 Thanks
  • 5,230 posts
Posted December 28, 2012 - 10:59 AM
... you look pissed...
The pictures where taken before I had any problems. I was mad because my brother kept trying to give me advice on how to plow. Once we took out the four wheeler, I told him to do it. He was on it for about 5 minutes and he gave up; do you think he said anything to me after that? :rolling:
#18 Ryan313 ONLINE
  • 3,365 Thanks
  • 5,230 posts
Posted December 28, 2012 - 02:40 PM
After looking at the pictures again, I was reminded of something; the chains need to be adjusted again! When I put them on I had to hold the tire up and put the chains on. Needless to say, I did not get them on very well.
#19 David Brown OFFLINE
David Brown
  • 4,510 Thanks
  • 2,424 posts
Posted December 28, 2012 - 03:50 PM
If your tires are loaded, just jack one wheel up off the ground and work the chains until they are tight.  That's how I do it and it works quite well.  If they are not loaded, let some air out, tighten the chains and inflate.  They will never move!
#20 Ryan313 ONLINE
  • 3,365 Thanks
  • 5,230 posts
Posted December 28, 2012 - 03:52 PM
That is exactly how I normally do it. I took them off this time because they had all kinds of junk and debris frozen into the links. I wanted to put them into the basement where it's warm so everything could melt off. And, the tractor was just a little bit to wide to fit through the door. :D
  • Moosetales said thank you
#21 countryboy88 OFFLINE
countryboy88
  • 100 Thanks
  • 143 posts
Posted December 28, 2012 - 03:55 PM
Time for a bigger door.   :D
