Tecumseh Intake Baffle Carburetor Isolator Plate?
isolator plate. tecumseh
18 replies to this topic
#1 robert_p43 OFFLINE
robert_p43
  • 572 Thanks
  • 534 posts
Posted December 26, 2012 - 12:32 PM
This is from my 10hp engine on my Sears Suburban 10.  Tecumseh HH-100
When I took my carb off for rebuilding, there was a piece of heavy sheet metal behing the carb.  On ebay, I just spotted this item. One listing said, "Intake baffle carburetor isolator plate,"  The other just said, "carburetor isolater plate."
What is the purpose?  I don't remember seeing this in the manuals that I have downloaded. Does it need an intake gasket on each side?  Mine only had one on the caeb side but who knows if one had been lost before I got the tractor.
Here is one of the pics from one of the ads.
#2 chris m OFFLINE
chris m
  • 3,338 Thanks
  • 4,063 posts
Posted December 26, 2012 - 01:04 PM
I think it just acts heat sink. some engines use a wide vs long adapter. Tecumseh probably found the fuel was getting to hot before it entered the intake port. And space may have been limited so they came up with a long design like this?
If the fuel gets to hot it won't atomize as well and it could even boil the fuel causing a vapor lock.
  • HDWildBill and robert_p43 have said thanks
#3 robert_p43 OFFLINE
robert_p43
  • 572 Thanks
  • 534 posts
Posted December 26, 2012 - 02:51 PM
This would explain something that happened years ago, not tractor related.  I stopped to help a camper that was beside the road.  I would not start.  A man who worked for the state crew, driving a dump truck stopped.  After trying a few things, the state worker asked the wife if she had a clothes pin in the camper, the snap kind and she said, "I think we do."  She went in and came out with one.  The state worker squeezed it and clipped it onto the metal fuel line right before the carburator.  The camper started right up.  The State guy said, " Vapor lock, just as I thought."  I asked him how that works and he said he didn't know how, only that it does work.  Now I know why it works.
Thank You
#4 HDWildBill OFFLINE
  • 8,975 Thanks
Posted December 26, 2012 - 03:21 PM
I would say yes you need a gasket on both sides, otherwise it is liable to suck air in and your mixture will be to lean.
I've heard you can also use aluminum foil as well as a clothes pin.
  • chris m and robert_p43 have said thanks
#5 Amigatec OFFLINE
Amigatec
    Collector of Rusty Junk
  • 2,025 Thanks
  • 3,172 posts
Posted December 26, 2012 - 03:24 PM
I bought a new carb for my HH120, and it came an aluminum plate instead to steal. Yes I would say its a heat sink.
#6 chris m OFFLINE
chris m
  • 3,338 Thanks
  • 4,063 posts
Funny you say that. I that a camper that I had to pullover and let it sit for 5 minutes then I could drive for another 20 minutes, then same thing. So I rebuilt the carb changed fuel pump new filter and all. because every time it happened I would look down the throat of the carb, moved the throttle and no gas would spray in the venturi. after all that I decided to trace the fuel line, I found that a PO had routed the fuel line and actually had it laying on the right exhaust manifold, so needless to say it was boiling the fuel and causing a vapor lock. After I re routed the line I never had a problem again.
Interesting about the clothes pin, I can't figure what or how that would  do anything? hmmm. heat sink I guess?
#7 chris m OFFLINE
chris m
  • 3,338 Thanks
  • 4,063 posts
Posted December 26, 2012 - 03:26 PM
Ya my HH120 has a gasket on both sides with that same plate.
  • robert_p43 said thank you
#8 Bruce Dorsi OFFLINE
Bruce Dorsi
    Old, but not dead -- yet!
  • 3,915 Thanks
  • 2,451 posts
Posted December 26, 2012 - 06:17 PM
 In addition to acting as a heat sink to dissipate heat away from the carb as already mentioned, on some engines, these plates also helped contain and direct the airflow from the flywheel toward the cooling fins near the exhaust.  .....The airflow against the back of the baffle is what carried the heat away from the carb.
And, yes, as already stated, you need a gasket on each side of the plate.
  • Alc, HDWildBill and robert_p43 have said thanks
#9 MH81 OFFLINE
Posted December 26, 2012 - 09:36 PM
Another vote for two gaskets.
No wonder you were having some starting issues.  That would make a HUGE difference in mixture, especially when pull starting it.
If you don't have any gasket material around, might be time to pick some up.  This is a simple gasket to cut out.
#10 robert_p43 OFFLINE
robert_p43
  • 572 Thanks
  • 534 posts
Posted December 26, 2012 - 10:45 PM
I was thinking about this issue since it wasn't sucking in the fuel.  I ordered a few items from sears today and should have the tractor inside by the time the stuff arives.  With Christmas, my son being here, trying to get some firewood stocked and now the ice.  Things have been to busy to re-arrange my little building and get a proper workbench set up and have a little elbow room to work on my tractor.  Right now, with the little snow turning to ice, I can't even get the doors to the shed opened.  Wish I could, I have a bag of ice melt in there.
#11 MH81 OFFLINE
Posted December 26, 2012 - 10:52 PM
:rolling:
Been there. Not funny, but I could just hear the tone in your text and it made me laugh.
  • chris m said thank you
#12 chris m OFFLINE
chris m
  • 3,338 Thanks
  • 4,063 posts
Posted December 26, 2012 - 11:06 PM
:rolling:
Same here lol. Then it's " Oh I'll just use the shovel to chip away at it" awww " The shovel is in the shed too!" :wallbanging:
  • MH81 and HDWildBill have said thanks
#13 MH81 OFFLINE
Posted December 26, 2012 - 11:08 PM
Next thing you know, you're using your brand new Christmas screwdriver as an ice pick, not because it's the best tool for the job, but because it's the only thing other than a steak knife that's not out in the shed...
And it has a lifetime guarantee. :D
  • HDWildBill and chris m have said thanks
#14 chris m OFFLINE
chris m
  • 3,338 Thanks
  • 4,063 posts
Posted December 26, 2012 - 11:17 PM
Alan when I was younger. same type of thing happened. I said hmm I'll just hook a hose to the hot water heater and melt all that ice! Needless to say our driveway could have been used for ice skating after I was done. I had no clue back then that hot water freezes faster than cold water LOL.
  • Alc and HDWildBill have said thanks
#15 robert_p43 OFFLINE
robert_p43
  • 572 Thanks
  • 534 posts
Posted December 27, 2012 - 08:35 AM
You guys are cracking me up! :rolling:
I only want the ice melt for the back step but then again, if she is brave enough to drive in this weather, she can certainly brave that back step.  When I was her age, I would have driven on these roads too.  Now?  I would be better off sitting here, in front of the woodstove, keeping warm, and dreaming about springtime.
