Anyone Know How Much Its Worth?
21 replies to this topic
#1 Mitchel OFFLINE
Mitchel
  • 5 Thanks
  • 39 posts
Posted December 25, 2012 - 07:45 PM
does anyone know how much this tractor is worth? the owner wants to trade for something i have and i want to know how much its worth. told me it was a 1956 cub cadet. 8 horse engine with the original deck. any help would be appreciated.
Thanks, Mitch
#2 Bolens 1000 ONLINE
  • 15,279 Thanks
  • 18,232 posts
Posted December 25, 2012 - 07:51 PM
I dont know much about Cub's but looks to be missing the fenders/original seat assembly and was probably made in the 60's not 50's.
#3 Cat385B ONLINE
    HAZMAT CAT
  • 14,258 Thanks
  • 10,106 posts
Posted December 25, 2012 - 07:53 PM
Is the deck in working condition?
The Cub Cadet (Original) was made from 60-63.
#4 Jack OFFLINE
Jack
  • 1,309 Thanks
  • 861 posts
Posted December 25, 2012 - 07:54 PM
Well I am no expert on cubs but I think hes off by at least 10 years.   I dont think they made any cubs before the early 60's   I would guess its worth somewhere between 3 or 4 hundred bucks if it runs ok.  And that might be on a good day.   Thats about all I would want to put in it.  I am sure some CC guys can inform you much better than I can.
Jack..
#5 Amigatec OFFLINE
Amigatec
    Collector of Rusty Junk
  • 2,026 Thanks
  • 3,172 posts
Posted December 25, 2012 - 08:17 PM
It appears to be a Cub Cadet Original, but they had a 7 HP motor, if it has an 8 HP it has been replaced. The seat has been replaced as well as the wheels and tires. It would be better if you had more pictures.
#6 LTD OFFLINE
LTD
    Cub Cadet Collector
  • 1,035 Thanks
  • 1,457 posts
Posted December 25, 2012 - 08:25 PM
I would give 200-250 for that in my area. The seat and exhaust are wrong along with some other small things.It should have a hood bird also. If it really has an 8 horse engine that is not correct either. The Original Cub Cadet had a 7 horse Kohler engine. Definitely not a '56 either as the other guys said, 61-63 is when they made them. Looks to be in pretty decent shape other than that. If the deck is in nice condition that would add 50-100 to the price. One thing to check for on the deck would be the cogged belt for the timed blades. If it is loose it will slip and cause the blades to clash. There is no tightener for that belt either and they aren't cheap!!! Another thing to check is where the frame bolts to transmission, the frame is prone to break around the bolt holes.
#7 Mitchel OFFLINE
Mitchel
  • 5 Thanks
  • 39 posts
Posted December 25, 2012 - 08:38 PM
looks like im going with the other mower i was offered then. i dont want something that has been messed around with too much and has different pars from different things
#8 LTD OFFLINE
LTD
    Cub Cadet Collector
  • 1,035 Thanks
  • 1,457 posts
Posted December 25, 2012 - 08:43 PM
  What is the other one?
#9 Mitchel OFFLINE
Mitchel
  • 5 Thanks
  • 39 posts
Posted December 25, 2012 - 08:47 PM
18 horse dynamark with a snow blower. blower looks to be around 42 inch.
#10 JDBrian OFFLINE
  • 9,634 Thanks
  • 14,156 posts
Posted December 26, 2012 - 08:59 AM
If you need a blower than that may be the way to go but the Cub, even if messed with, has more potential. It all depends on what you are trading and what you need. A snowblower is a valuable implement if you have a use for one.
#11 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted December 26, 2012 - 03:14 PM
I can't help much on value. But here is a site with good info on Cadet Model Progression.
http://www.xtrememot...det_History.htm
#12 nhironworks OFFLINE
nhironworks
  • 37 Thanks
  • 15 posts
Posted December 30, 2012 - 09:37 AM
Mitch-if you can get the owner to shoot over the SN I can get you the date it was built. For sure it was made between 61 and 63, and it is not a super early one as there is a hole for the creeper option I see. It's value around here with a deck and running shape is ballpark $350-$400 as a guestimate.  The Cub Cub Cadet though will be far easier to locate parts for than the Dynamark will be, and is certainly more valuable fixed up. The "Originals" as they are nicknamed, are becoming a bit harder to find and bring pretty good money restored.  Implements are not too bad to find as well, though the originals not as easy as the rest of the cubbies.
#13 Mitchel OFFLINE
Mitchel
  • 5 Thanks
  • 39 posts
Posted December 30, 2012 - 02:44 PM
i got the cub. it doesnt say cub cadet anywhere on it. the hood decal just says 'McCormick International'. it runs great and drives pretty good too. where would the sn be located?
#14 Amigatec OFFLINE
Amigatec
  • 2,026 Thanks
  • 3,172 posts
Posted December 30, 2012 - 02:58 PM
It should be hand stamped on the right side of the tranny.
#15 Mitchel OFFLINE
Mitchel
  • 5 Thanks
  • 39 posts
Posted December 30, 2012 - 03:18 PM
the numbers say 351520-R7
