hello looking for bolens parts
9 replies to this topic
#1 tman OFFLINE
tman
  • 13 posts
Posted August 31, 2010 - 10:48 AM
I have a Bolens fmc g14 and i am looking for the motor shroud it is a 14hp Wisconsin if any one can help me out i would be much appreciative.thank and have a great day
#2 olcowhand ONLINE
  • 42,900 Thanks
  • 31,942 posts
Posted August 31, 2010 - 11:17 AM
Contact Bob, maybe he has it. Here's link to his member page, you can PM him from there:
http://www.gttalk.com/members/bhts/
  • tman said thank you
#3 tman OFFLINE
tman
  • 13 posts
Posted August 31, 2010 - 05:28 PM
ok thank you i will try bob
#4 Bolens 1000 ONLINE
  • 15,440 Thanks
  • 18,288 posts
Posted August 31, 2010 - 05:54 PM
The 14HP wisconsins are hard to get parts for....
If Bob does not have one you can check sams Bolens or ebay.
#5 bhts OFFLINE
bhts
  • 1,476 Thanks
  • 2,169 posts
Posted August 31, 2010 - 06:15 PM
I have them.But the G-14 came with a tecumseh.Was the motor replaced?Also the wisconsin 14hp would be a hard fit in the tractor without the hood being cut as it is alot taller motor so are you sure it is a wisconsin.
#6 Bolens 1000 ONLINE
  • 15,440 Thanks
  • 18,288 posts
Posted August 31, 2010 - 06:20 PM
You got a good point there Bob. That wisconsin would have a hard time fitting in there without some cutting/fabbing
Pics would help greatly...
#7 tman OFFLINE
tman
  • 13 posts
Posted August 31, 2010 - 06:37 PM
oh ok maybe it is tecumseh because the hood has not been cut .is their a model# on the block on these motors or just the shroud ?
#8 tman OFFLINE
tman
  • 13 posts
Posted August 31, 2010 - 06:41 PM
ok if bob dosn't have one i will try sam thanks for your help
#9 Bolens 1000 ONLINE
  • 15,440 Thanks
  • 18,288 posts
Posted August 31, 2010 - 08:39 PM
I'm not sure where the # are for the tecumseh's.
Is there any way you can upload a picture?
#10 bhts OFFLINE
bhts
  • 1,476 Thanks
  • 2,169 posts
Posted August 31, 2010 - 08:54 PM
There is no other place for the model number other then the shroud.On the flyweel side of the motor at the lower left side there should be a number like 14 stamped into the block if it is a 14hp.Does the motor have overhead valves if so it is a tecumseh.Pics could help.
