Got My New David Bradley Home
41 replies to this topic
#31 Amigatec OFFLINE
Amigatec
    Collector of Rusty Junk
  • 2,025 Thanks
  • 3,172 posts
Posted December 23, 2012 - 01:36 PM
It is normally used for reverse.
#32 bigcountry48 OFFLINE
bigcountry48
  • 101 Thanks
  • 207 posts
Posted December 23, 2012 - 01:44 PM
Would it only go in reverse, or still go forward? Probably a stupid question, but I'm clueless.
#33 Amigatec OFFLINE
Amigatec
  • 2,025 Thanks
  • 3,172 posts
Posted December 23, 2012 - 01:46 PM
Just use the crankshaft it will spin the correct direction.
#34 Amigatec OFFLINE
Amigatec
  • 2,025 Thanks
  • 3,172 posts
Posted December 23, 2012 - 01:47 PM
If you need the PTO shaft just don't use it. Use the crank instead.
#35 bigcountry48 OFFLINE
bigcountry48
  • 101 Thanks
  • 207 posts
Posted December 23, 2012 - 01:54 PM
Nice grouping of implements and a good starting point for a restored tractor.
Now, I am no DB guru by any stretch, but I see a couple of things.
IDT the engine is original.
Here's a picture from Pat's Website
The plow that's mounted on the back is either a middle buster or a potato digger.
The unknown attachment almost has to be some kind of cultivator , weeder or etc rig, I hope someone can pinpoint it for you.
Thanks for Sharing your new tractor with us!
Is that the correct original engine?
#36 Amigatec OFFLINE
Amigatec
  • 2,025 Thanks
  • 3,172 posts
Posted December 23, 2012 - 02:00 PM
The correct motor is a Briggs and Stratton model 143302 at 6 HP. Your Tractor is about a 1962 model.
#37 Amigatec OFFLINE
Amigatec
  • 2,025 Thanks
  • 3,172 posts
Posted December 23, 2012 - 02:06 PM
Here is how you would use the PTO for reverse, this is on my TroyBilt Pony Tiller.
There or 2 belt tighteners, the bigger pulley is on the crank and is tightened to go forward. The small pulley is on the PTO shaft and is tightened to go in reverse.
There is a 3 groove pulley on the transmission.
You only tighten one belt at a time.
Edited by Amigatec, December 23, 2012 - 02:07 PM.
#38 bigcountry48 OFFLINE
bigcountry48
  • 101 Thanks
  • 207 posts
Posted December 23, 2012 - 02:11 PM
OK, I think I understand. So the 5 horse will work just fine, is it worth shipping and me trying to save?
#39 Amigatec OFFLINE
Amigatec
  • 2,025 Thanks
  • 3,172 posts
Posted December 23, 2012 - 02:20 PM
Here is the same type of motor mounted on my 5756, I had to remove the hood to make it fit.
#40 Amigatec OFFLINE
Amigatec
  • 2,025 Thanks
  • 3,172 posts
Posted December 23, 2012 - 02:21 PM
I can try to starting it.
#41 Virginia Mike OFFLINE
Virginia Mike
  • 16 Thanks
  • 30 posts
Posted December 24, 2012 - 07:25 AM
Do you know where I could get one?
I'm afraid not.
I got one on a "Super Power" I bought. The plate and engine was painted gold, so it's late '50's vintage.
The engine still has one of the "Low Tone" mufflers on it. I will restore it for display with the catalog page that shows the upgrade
  • bigcountry48 said thank you
#42 bigcountry48 OFFLINE
bigcountry48
  • 101 Thanks
  • 207 posts
Posted December 24, 2012 - 07:54 AM
That will look great! looking forward to seeing it when it's done!
