Got My New David Bradley Home
41 replies to this topic
#16 bigcountry48 OFFLINE
bigcountry48
  • 101 Thanks
  • 207 posts
Posted December 22, 2012 - 07:26 PM
The only idenification mine has on it is the tag I posted a picture of. It does have a carburetor, but no air filter and it turns over (probably because, the hole is most likely from a slung rod) I would be very appreciative if you'd be willing to trade, and I'm sure the DB would be to!
#17 bigcountry48 OFFLINE
bigcountry48
  • 101 Thanks
  • 207 posts
Posted December 22, 2012 - 07:41 PM
Congrats on the new toy. I have a pair of wheel weights like those on my Magna-Trac parts tractor. Do yours have a label? The engine is not the correct one for the tractor. Good Luck
Yes, I'll go look and see what the numbers are tomorrow.
#18 Amigatec OFFLINE
Amigatec
    Collector of Rusty Junk
  • 2,025 Thanks
  • 3,172 posts
Posted December 22, 2012 - 07:43 PM
I'd be more interested in the adjustable foot. :wave:
  • bigcountry48 said thank you
#19 Amigatec OFFLINE
Amigatec
  • 2,025 Thanks
  • 3,172 posts
Posted December 22, 2012 - 07:47 PM
One thing you might check is the motor mount plate, it may be different. On my 575144 there are reinforcements on the on the plate, it is shipped with a 6 HP Tec motor. When somebody mounted the 8 HP motor they may have modified the plate for the bigger motor.
#20 Virginia Mike OFFLINE
Virginia Mike
  • 16 Thanks
  • 30 posts
Posted December 23, 2012 - 06:25 AM
Sears also sold a mount plate with their re-power kits. It has theaded bosses to bolt the engine on, and the kick stand is on the other side.
#21 Farmlife OFFLINE
Farmlife
    Tractor Whisperer
  • 1,233 Thanks
  • 1,461 posts
Posted December 23, 2012 - 06:36 AM
that's nice, I think with everything you got you didn't really get taken. You have alot to work with there. From what I can tell I would say its right about a 1958-59. That's where the serial number brings you. Congrats, can't wait to see it finished...
#22 Alc ONLINE
  • 6,740 Thanks
  • 7,395 posts
Posted December 23, 2012 - 06:45 AM
Glad to hear you got a DB , be careful they start to grow quickly , before you know it you'll have more ,lol. Is this going to be a tractor your going to use or for show ? Either way you'll have fun with it , Al
#23 Amigatec OFFLINE
Amigatec
  • 2,025 Thanks
  • 3,172 posts
Posted December 23, 2012 - 07:33 AM
I know my older models have the kickstand on the right, and my 144 has it on the left. I don't know when they changed over.
#24 mjodrey OFFLINE
Posted December 23, 2012 - 07:35 AM
Congratulations on your new DB.
#25 bigcountry48 OFFLINE
bigcountry48
  • 101 Thanks
  • 207 posts
Posted December 23, 2012 - 08:19 AM
I plan to do not a full resto, just a refurbish and some rattle can painting. It will be a chore tractor, and will definatly be at the Inman Farm Heritage Days Show next year!
#26 bigcountry48 OFFLINE
bigcountry48
  • 101 Thanks
  • 207 posts
Posted December 23, 2012 - 08:21 AM
Do you know where I could get one?
#27 Amigatec OFFLINE
Amigatec
  • 2,025 Thanks
  • 3,172 posts
Posted December 23, 2012 - 08:28 AM
A 5 HP Briggs should bolt down on the original plate just fine. I mounted one on my 5756 without drilling any new holes.
I'll go out in a bit and take some more pictures of the 2 different mounts.
#28 Amigatec OFFLINE
Amigatec
  • 2,025 Thanks
  • 3,172 posts
Posted December 23, 2012 - 09:14 AM
Here are some more pictures of it.
Here is the PTO shaft, it is an extension of the Camshaft and spins at 1/2 speed and in the opposite direction.
Here is where the throttle cable hooks up.
It also has a rod sticking up beside the carb, I believe this was for a manual throttle.
Here is the mount on my 5751 it has extra holes and the kickstand is on the left side.
Here is the mount on the 575144. It has the kickstand on the rightside.
Here is the extra reenforcement, it had a plate thin steel plate and 4 pipe spacers under it. I was shipped with a 6 HP Tec motor.
#29 Amigatec OFFLINE
Amigatec
  • 2,025 Thanks
  • 3,172 posts
Posted December 23, 2012 - 09:16 AM
I don't see any numbers on the motor, and it doesn't have any oil in it. The carb linkage is free, and it appears to be complete.
#30 bigcountry48 OFFLINE
bigcountry48
  • 101 Thanks
  • 207 posts
Posted December 23, 2012 - 12:56 PM
You said that it spins opposite of the original? How would I overcome this obstacle?
