Older Ford/Jacobsen Model Numbers
77 replies to this topic
#61 sap happens OFFLINE
sap happens
  • 17 Thanks
  • 25 posts
Posted March 05, 2016 - 08:35 AM
Yes it dose run. It could use a new muffler. I also have a 1969 ford 100, 1967 ford 120 and a 1969 Jacobsen super chife. I have not seen many 80s. Are they probably the rarest tractor out of the Ford made?
  • TomLGT195 said thank you
#62 KennyP ONLINE
  • 40,888 Thanks
  • 47,094 posts
Posted March 05, 2016 - 08:49 AM
I wouldn't use rare, but far and few between!
  • sap happens said thank you
#63 sap happens OFFLINE
sap happens
  • 17 Thanks
  • 25 posts
Posted March 05, 2016 - 08:52 AM
What is the front of the tractor supposed to look like? I believe I am missing the decal?
Edited by sap happens, March 05, 2016 - 09:27 AM.
#64 KennyP ONLINE
  • 40,888 Thanks
  • 47,094 posts
Posted March 30, 2016 - 04:58 PM
Just found this. Not sure what it should have up there.
#65 Heatherhelper OFFLINE
Heatherhelper
  • 1 posts
Posted July 10, 2016 - 05:19 AM
I'm hoping someone can help me confirm which Jacobsen mower deck I've got on my hands.  It's on a GT 16H and the model number on the deck is UT-36015.  I think it is the 50" but haven't been able to confirm it.  Thanks!
#66 KennyP ONLINE
  • 40,888 Thanks
  • 47,094 posts
Posted July 10, 2016 - 06:26 AM
:wave: Welcome to the forum. Not familiar with that deck #, so it could be.
Easiest way is to set the two outside blades in line with each other and measure the width of cut. Or, if you have some grass high enough, make a pass through and measure the width of that cut.
#67 Leighton OFFLINE
Leighton
  • 2 Thanks
  • 3 posts
Posted September 22, 2016 - 12:52 PM
I see no one has posted to this for a few years, but, I have recently picked up an older model Ford 120. The serial number is 53520 13129. From what I had found, I believed it to be a 70 model, but, I see it is a 69 model. Thanks for the info. I am going to be looking for some parts, if anyone has any good leads. Thanks!
#68 KennyP ONLINE
  • 40,888 Thanks
  • 47,094 posts
Posted September 22, 2016 - 01:58 PM
I can not attest to what is posted is totally correct, just what I have found thus far.
  • Leighton said thank you
#69 Leighton OFFLINE
Leighton
  • 2 Thanks
  • 3 posts
Posted September 25, 2016 - 06:49 PM
#70 Leighton OFFLINE
Leighton
  • 2 Thanks
  • 3 posts
Posted September 25, 2016 - 06:54 PM
That's ok Kenny. It's a 69 or 70. Pretty much the same parts. I have done some work on it and have been able to get it running and moving. I still need to get the carb set correctly (it's a gas hog right now). I was asked to bring it to a tractor show, no matter the shape. I am hoping I will be able to connect with someone who has parts. I know I need a seat and rear fender section the seat mounts to. I am also going to be looking for a gas tank and head lights (the headlights are both cracked). I would like to completely restore it. A few other issues with power and speed, but, I will work on that as time goes.
#71 FordFord140 OFFLINE
FordFord140
  • 14 Thanks
  • 8 posts
Posted January 07, 2017 - 10:41 PM
Trying to confirm that this is a 69 but if someone can confirm it I would appreciate it.
Ford 140 serial number 53265 1725
20170107 181700
#72 KennyP ONLINE
  • 40,888 Thanks
  • 47,094 posts
Posted January 08, 2017 - 05:01 AM
It very well could be a 1969. The list I have here is by no means complete. It is just what I have been able to put together from manuals and such. Nice score on that one.
One thing that may help is all the engine #s. We can date the engine and know the tractor was built after that. So post thase #s and we'll see what we find.
#73 FordFord140 OFFLINE
FordFord140
  • 14 Thanks
  • 8 posts
Posted January 09, 2017 - 11:04 AM
Thanks, Picked it up without looking it over mush. I figured for $200 heck with it. It runs and the transmission moves forward and reverse. Thats as far as I got. 16 degrees out!
20170109 095025 (2)
#74 KennyP ONLINE
  • 40,888 Thanks
  • 47,094 posts
Posted January 09, 2017 - 04:47 PM
Thanks! The letter E in the serial says its a 1969. Sounds about right! But it could be a 1970, just depends.
#75 hbower OFFLINE
hbower
  • 22 Thanks
  • 27 posts
Posted April 01, 2017 - 11:04 AM
Where is the serial no. located on the gt16? got mine yesterday. :rocker2: Thanks
