Ff 20 Repairs
sears ff20 axle seals hydro fan
34 replies to this topic
#31 KennyP ONLINE
  • 38,499 Thanks
  • 45,982 posts
Posted January 18, 2013 - 05:05 AM
Thanks for the heads up, Eric. I'll be looking into that on both tractors. It'll be Spring before I can start on it. The first one is working okay, not sure on the other until I get an engine on it. I can get the wheels cleaned up and painted as weather permits.
#32 KennyP ONLINE
  • 38,499 Thanks
  • 45,982 posts
Posted January 18, 2013 - 07:46 AM
Along with the wheels, I got a very nice hydro fan. I did use a Ford fan for the one I put on it a while back. Thought I would document the difference from the Ford to the Sears original fan for you guys.
The Sears is a full 7" dia, while the Ford is only 6.5". The Sears also is more robust (ie: bigger blades, thicker).
The Sears does have a small flat area where if fits on the shaft. Hard to see in the pic, it's right on the bottom in the pic.
Too bad they aren't available anymore!
  • stripmine said thank you
#33 Hugh OFFLINE
Hugh
  • 171 Thanks
  • 171 posts
Posted January 18, 2013 - 08:41 AM
Looking good Kenny. Planning on new tires in the back I assume?
#34 KennyP ONLINE
  • 38,499 Thanks
  • 45,982 posts
Posted January 18, 2013 - 09:29 AM
Nope, I'll use these up. They'll get cleaned well, maybe something to make them look better. I'll look them over real good inside and see if I can get by with out the tubes. If so, I can load them easier. But, the extra wheels will be nice for letting the paint set up good before mounting.
#35 mjodrey OFFLINE
  • 2,356 Thanks
Posted January 18, 2013 - 09:37 AM
Lookin' good there ,Kenny.
Also tagged with one or more of these keywords: sears ff20, axle seals, hydro fan
