Linear Actuator
11 replies to this topic
#1 MH81 OFFLINE
  • 29,979 Thanks
Posted December 19, 2012 - 10:50 PM
Has anyone ever used these actuators? They seem to spec well. Just making a wish list and saw the 750# specs, thought that'd do the trick for a 3 point hitch.
  • 14,889 Thanks
  • 15,514 posts
Posted December 19, 2012 - 11:01 PM
Seems to be a good one Alan, 16 second full stroke.
#3 HowardsMF155 ONLINE
  • 2,968 Thanks
  • 3,018 posts
Posted December 19, 2012 - 11:05 PM
Have you looked closely at ALL the specs? Only 175 lbs dynamic, and only moves at 1/4 inch/sec. So, 16 sec for full travel.
#4 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted December 19, 2012 - 11:09 PM
I have not, but around the net i have seen several people who have used them for 3 point and more often sleeve hitch lift.
And snow blade lifts. I even saw a guy selling plans for a GT loader using long stroke actuators.
I also saw a guy that used a pair of actuators under a Toyota flatbed dump unit.
They interest me quite a bit and I would be perfectly comfortable with your spending your money to see how they work for you.
#5 MH81 OFFLINE
  • 29,979 Thanks
Posted December 19, 2012 - 11:19 PM
Yeah, 16 seconds is a little slow. I didn't see the details tab on the Ipad,
Nevermind
#6 wvbuzzmaster OFFLINE
  • 4,717 Thanks
Posted December 20, 2012 - 12:05 AM
This is the best place to get actuators:
https://www.surplusc...ic&keyword=EALD
These are the actuators they are using on the Johnny Products sleeve hitches.
https://www.surplusc...atname=electric
  • ducky, MH81 and chris m have said thanks
#7 wvbuzzmaster OFFLINE
  • 4,717 Thanks
Posted December 20, 2012 - 12:08 AM
If you like a good 24 volt actuator I have my eye on this one:
#8 robert_p43 OFFLINE
robert_p43
  • 572 Thanks
  • 534 posts
Posted December 20, 2012 - 09:48 AM
Casey, that one in your second link looks like a good one. 500 pounds dynamic lift and max load it still moves half an inch per second.
#9 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted December 20, 2012 - 11:31 AM
Alan the specs are deceiving on that. The 750lbs is the static load. The push/pull is only 175. If you need 10" of lift on your 3 pt. from a 4 inch actuator then you can divide that figure by 2.5 to find out how much weight you would lift. The answer comes out to not enough.
#10 wvbuzzmaster OFFLINE
  • 4,717 Thanks
Posted December 20, 2012 - 12:38 PM
Like I said, it is the one that is used by Johnny Products on their sleeve hitch retrofits. If it is good enough for them than it would work great for Alan's Sears.
#11 olcowhand ONLINE
  • 42,898 Thanks
  • 31,941 posts
Posted December 20, 2012 - 09:14 PM
I was gonna say that 16sec is terribly slow. We put a linear actuator on our silage chopper trans to reverse the feederhouse tranny. It's a 6" stroke and takes only about 4 seconds full stroke. We got it from Surplus Center.
#12 boostedbuick OFFLINE
boostedbuick
  • 73 Thanks
  • 84 posts
Posted December 21, 2012 - 09:47 PM
An idea for the poor man is to go junkyarding and rob the cylinders off a convertible top mechanism. Almost all are hydraulic linear cylinders with a remote 12v motor/pump and will do push/pull function. Big enough for a 3 point? I won't pretend to know, but you get to use both actuators :) . I know my dad's 65 sport fury uses them and that top isn't light!
I had a complete sealed system off a toyota celica a couple years back but got tired of storing it with no purpose. It met the dumpster and I probably shouldn't have done that.
Edited by boostedbuick, December 21, 2012 - 09:50 PM.
