Cleaning Cast Iron
4 replies to this topic
#1 1978murray OFFLINE
1978murray
    diesel mechanic
  • 607 Thanks
  • 1,165 posts
Posted December 19, 2012 - 09:03 AM
Im restoring a 1950s lauson RSH. its in rough shape with may coats of paint and rust. What is the best way to clean cast iron and get in all the cooling fins ect.
#2 JRJ OFFLINE
JRJ
  • 876 Thanks
  • 1,170 posts
Posted December 19, 2012 - 09:27 AM
I would give serious consideration to sand blasting or maybe a softer media to do the blasting.
Dick
#3 olcowhand ONLINE
  • 42,334 Thanks
  • 31,783 posts
Posted December 19, 2012 - 09:32 AM
I've sandblasted them before, but the thick baked grease/grime is hard to blast off with smaller less powerful blasters. Scraping the thick stuff off, then degreaser, then follow with a blaster & you can eat off it.
#4 Byron R OFFLINE
Byron R
  • 57 Thanks
  • 120 posts
Posted December 19, 2012 - 06:09 PM
I've had good results stripping old grease and paint with cheap oven cleaner from Wallyworld..Dollar General...and a Power Washer.. just a Idea...
#5 glgrumpy OFFLINE
  • 8,719 Thanks
  • 7,973 posts
Posted December 20, 2012 - 05:09 PM
I blast everything! Scrape off thick stuff, power wash works if summer or good hose and Gunk cleaners. Then Blast. You'll have to tear down to almost every part tho, it gets into tight areas like bearings no matter how careful you are. Thick grease not cleaned off or any rubber won't blast......just get's "snotty" on grease, rubber cleans and won't get harmed. But, the rubber might be hiding rust underneath it!
