Bolens Husky Pup
18 replies to this topic
#1 Tractorbuds OFFLINE
Tractorbuds
  • 15 Thanks
  • 44 posts
Posted December 18, 2012 - 03:40 PM
Anybody restoring a Pup and need parts? I rescued one from the scrap yard with plans to do a resto-mod and will be getting rid of the deck and associated accessories, rims, and potentially a few other bits. All that was missing was the motor. The original seat is still there underneath the new covering.
How rare are these mowers? Any demand for parts?
Cheers
  • OldBuzzard and goodnews have said thanks
#2 Bolens 1000 ONLINE
  • 17554 Thanks
  • 18863 posts
Posted December 18, 2012 - 03:44 PM
Not many people are collecting the Pups
Since there are quite a few around the prices on these tend to be fairly low, Normally you can get a running one in decent shape complete with deck for $200 or less
  • goodnews and Tractorbuds have said thanks
#3 JDBrian OFFLINE
  • 9682 Thanks
  • 14162 posts
Posted December 18, 2012 - 04:52 PM
I don't think I've seen one of those before. Seems odd that with so many Bolens collectors nobody is interested in them. It's a neat looking little mower.
#4 Bolens 1000 ONLINE
  • 17554 Thanks
  • 18863 posts
Posted December 18, 2012 - 04:56 PM
These were designed for "light duty" work which is why people tend not to collect them
Most are into the Heavy duty Largeframe & Tubeframe models which were more rugged and versatile
#5 JDBrian OFFLINE
  • 9682 Thanks
  • 14162 posts
Posted December 18, 2012 - 05:00 PM
It looks pretty light but the styling is so similar to the larger tractors it would be a nice addition to a collection IMO even if just for the cuteness factor.
#6 Cat385B OFFLINE
    Tractorfanatics.com
  • 14751 Thanks
  • 10288 posts
Posted December 18, 2012 - 05:12 PM
I like to think that I pay attention to the Bolens machines. I've never seen one before, most likely for the reasons Bolens 1000 listed. The small rear tires are odd-looking on a Bolens, mainly because I'm not used to seeing it, I guess.
I'll check the site guidelines, but I'm pretty sure you get a warning point for using 'cuteness factor' anywhere outside of pictures with grandchildren on tractors. I'll check, but I think you're in trouble, Mister.
:biting_nails:
  • MailmAn said thank you
#7 Bolens 1000 ONLINE
  • 17554 Thanks
  • 18863 posts
Posted December 18, 2012 - 05:45 PM
The tires are not original on that Tractor
Here's some info on it:
Bolens even referred to it as "Lawn Tractor"
  • grand and goodnews have said thanks
#8 Cat385B OFFLINE
    Tractorfanatics.com
  • 14751 Thanks
  • 10288 posts
Posted December 18, 2012 - 06:04 PM
Holy Moly, it has a wash out port on the mower deck! Is it a hose connection, or just hole in the deck? What year did that show up? Only took other manufacturers about 40 years to try that out.....
#9 Bolens 1000 ONLINE
  • 17554 Thanks
  • 18863 posts
Posted December 18, 2012 - 06:15 PM
Bolens was often years ahead of the competition when it came to new features.
They added the wash ports in 1967. You pull a cap off and thread the hose into the fitting.
#10 goodnews OFFLINE
goodnews
  • 126 Thanks
  • 423 posts
Posted December 18, 2012 - 06:21 PM
thats what i'm thinking Brian .
Edited by goodnews, December 18, 2012 - 06:26 PM.
#11 goodnews OFFLINE
goodnews
  • 126 Thanks
  • 423 posts
Posted December 18, 2012 - 06:25 PM
i need a steering wheel that one sure does look good if you took it off a nd gave it a little push you think it woo make to n.c.its downhill l0l0l0. in Christ bobby
#12 wilberj OFFLINE
wilberj
  • 5552 Thanks
  • 5738 posts
Posted December 18, 2012 - 06:58 PM
Doc Let a guy with a 510 pup and 610 pup jump in here and say that my 510 has the same rear tires as that 510. :poke: :poke:
I would take it for parts if you were by me.
I have got all my pups under $125 so there not worth to much I believe bolens made alot of them.
#13 Bolens 1000 ONLINE
  • 17554 Thanks
  • 18863 posts
Posted December 18, 2012 - 07:20 PM
After some looking I think there were two different size tires available not 100% sure though......
#14 Mike Unwin OFFLINE
Mike Unwin
  • 409 Thanks
  • 306 posts
Posted December 18, 2012 - 07:26 PM
Is the deck shaft drive on the 510 ? I need a PTO type deck,last one was a MTD 990 stuck under my Bolens !
#15 Bolens 1000 ONLINE
  • 17554 Thanks
  • 18863 posts
Posted December 18, 2012 - 07:28 PM
No, These were belt driven
  • goodnews said thank you
