How Much Did It Cost You To Have A Cylinder Bored?
37 replies to this topic
#16 chris m ONLINE
chris m
  • 3,338 Thanks
  • 4,063 posts
Posted December 17, 2012 - 07:13 PM
Is this what you guys are talking about ?
http://allentown.cra...3416296103.html
Wow that's strange, I have never seen one like that before. Looks well made! I would like to find more information on these. Thanks!
#17 Arti OFFLINE
Arti
  • 1,363 Thanks
  • 989 posts
Posted December 17, 2012 - 08:22 PM
In SW Wisconsin the going rate is $75.
Our local Vo Tech school has a fixed honing machine. I took a nite course for small engines and managed to use it a couple of times. It works great. For one engine I honed it a few thousands to get the cylinder round and straight again and then knerlized the pistons (puts a cross hatch on the piston skirt and expands them slightly).
  • chris m said thank you
#18 Guest_rat88_*
Guest_rat88_*
  • Guests
Posted December 17, 2012 - 08:31 PM
I aint never seen that trick before. I guess thats what paid lernin' will get ya. I read once that the piston skirt is where the compression comes from and the rings are just there to keep the oil in.
#19 olcowhand OFFLINE
  • 41,070 Thanks
  • 31,392 posts
Posted December 17, 2012 - 08:38 PM
Here's a video of knurling a piston.
#20 brahlf ONLINE
brahlf
  • 11 Thanks
  • 24 posts
Posted December 17, 2012 - 08:39 PM
I just had my Kohler 16 hp sleeved this year. I believe I paid about $200 including the sleeve. Cylinder was .060 oversize. Boring should be about $100 unless you live somewhere out in the boon docks where the cost of living is a lot less expensive. Took mine to a automotive race shop, not too many places around that do sleeving anymore. I could have shipped it to down south but by the time I paid the freight I'm back to $200.
  • chris m and A.C.T. have said thanks
#21 Gtractor OFFLINE
Gtractor
    G-agressive tractor
  • 9,311 Thanks
  • 4,948 posts
$35 per cylinder here.
#22 marlboro180 ONLINE
marlboro180
  • 635 Thanks
  • 954 posts
Posted December 17, 2012 - 10:49 PM
A little less than 50 bucks a hole here.... at the local auto parts store that has an in house shop... has 'em resurface the valves too, another 25 bucks. I had to boil/ clean the block afterward though. They did a poor job of that...
#23 DougT OFFLINE
DougT
    Dog Approved
  • 6,925 Thanks
  • 4,993 posts
Posted December 18, 2012 - 08:11 AM
That's the same basic hone that I have. The big knob gets it out close and the little knob moves the stones in thousandths. Stones are replaceable and come in coarse, medium, and fine.
#24 Alc ONLINE
  • 6,883 Thanks
  • 7,459 posts
Posted December 18, 2012 - 08:34 AM
Doug would that be able to do a cylinder that had some taper to it ? One that comes to my mind right now was worn about .008" bigger at the top , thanks , Al
#25 HowardsMF155 OFFLINE
  • 2,861 Thanks
  • 2,987 posts
Posted December 18, 2012 - 10:00 AM
I was just checking locally today and was quoted $50 to bore the cylinder, and $50 to grind the crankshaft, with another $35 to reseat the valves.
#26 boyscout862 OFFLINE
  • 12,832 Thanks
  • 9,160 posts
Posted December 18, 2012 - 10:11 AM
I have that hone. I took a 12hp Briggs aluminum that was scored and honed it out to 0.010" over. It took an hour because I clean frequently and let the tool do the work. It came out straight and round( plus or minus 0.001") by taking it slow. The scratches were too deep so I got another block at the dump and overhauled it. But honing with the right tool and technique works well.
#27 DougT ONLINE
DougT
    Dog Approved
  • 6,925 Thanks
  • 4,993 posts
Posted December 18, 2012 - 10:17 AM
Sure, it will take out the taper or out of round. The thing you need to watch is bore size. I forget exactly what range mine is but I think it will only go down around 3 inch or a little more. They do make the same thing for smaller or bigger bores.
#28 chris m ONLINE
chris m
  • 3,338 Thanks
  • 4,063 posts
Posted December 19, 2012 - 02:34 PM
Well I just got back from dropping my block off to be bored out. I just hope the cylinder is at least round when I get it back, I am so not used to other people doing work for me. :biting_nails:
#29 MH81 ONLINE
Posted December 19, 2012 - 06:50 PM
Might want to start pricing new pistons. May I suggest this style?
#30 coldone OFFLINE
coldone
  • 1,651 Thanks
  • 1,679 posts
Posted December 19, 2012 - 06:52 PM
OHHHHHHH!!! Where? I got a K341 I need that done to. I do think I found a guy about 30 minutes from me, some go kart racers use him. I would like to have options though.
