Bolens 1250 Hydro Fluid Type?
6 replies to this topic
#1 Tractorbuds OFFLINE
Tractorbuds
  • 15 Thanks
  • 44 posts
Posted December 17, 2012 - 06:36 AM
Hi, sorry for another question, but I haven't had any luck searching older posts.
What kind of fluid are you putting in your 1250 hydro?
Manual says ATF type A - wondering if you can let me know your favourite brand, or particular brand that works best?
Are you using any additives?
Thanks.
#2 boyscout862 OFFLINE
  • 15273 Thanks
  • 10026 posts
Posted December 17, 2012 - 06:56 AM
We welcome your questions. I'm also impressed on your quick progress on your machine. This is a topic that has been discussed a few times here and on other forums with no real resolution. I thought the manual said Type "F" which is the old Ford trany fluid from the 60s and 70s. I came to the conclusion to use what the manual says for topping off until I change the fluid and filter. Then I will go to the "all tractor" fluid that many places sell, as long as it meets the specs. Someone here gave a good explanation a month or two ago.
#3 Tractorbuds OFFLINE
Tractorbuds
  • 15 Thanks
  • 44 posts
Posted December 17, 2012 - 07:54 AM
Looks like people are using the GM Dextron ATF or a multi-purpose tractor hydraulic type fluid. I'll stick with Dextron unless I hear otherwise because that's what's in it now. Just thought that if I am going to change the fluid, drain the lines, I better do a little research first. I have some time to let this post simmer because I still need a carb.
Regarding our pace, we like to keep moving forward quickly. I am working with an eleven year old and they don't make this too patient these days.
Here are some pics of last winter's project: 1963 Cub Original Resto-mod.
  • iron Mike, MailmAn and Austen have said thanks
#4 KennyP ONLINE
  • 53218 Thanks
  • 53323 posts
Posted December 17, 2012 - 08:05 AM
The Bolens folks will be along. They aren't early risers like some of us!
#5 goodnews OFFLINE
goodnews
  • 126 Thanks
  • 423 posts
Posted December 17, 2012 - 04:35 PM
wow !great job really impressed you do it right looks like. in Christ
#6 wilberj OFFLINE
wilberj
  • 5552 Thanks
  • 5738 posts
Posted December 17, 2012 - 07:47 PM
I use Dextron type F in all my large frames.
  • Bolens 1000 said thank you
#7 nyrobbie77 OFFLINE
nyrobbie77
  • 106 Thanks
  • 83 posts
Posted January 02, 2013 - 09:50 PM
we use tractor supply universal tractor fluid in my 1250, bro's gtx20, dad's ht20 and grams gtx18 for a few years now with no problems.  http://www.tractorsu...-2-gal--0806383
