No. Andover, Ma - Modified Sears Rear Blade And Hitch - $175
This topic has been archived. This means that you cannot reply to this topic.
5 replies to this topic
#1 Oo-v-oO ONLINE
Oo-v-oO
  • 341 Thanks
  • 448 posts
Posted December 16, 2012 - 11:47 PM
This appears to be a Sears rear blade that has been modified. Looks like it could be put back to original condition, though. If I read the ad correctly the Sears 3-point is included and if so this is a pretty good deal.
http://boston.craigs...3480758036.html
42" rear blade - $175 (North Andover, MA)
Date: 2012-12-15, 3:33PM EST
Reply to: see below
42" rear blade with manual hitch and adapter for mounting to John Deere LX Series lawn and garden tractor. (adapter can be modified for use with other tractors). Heavy duty blade can angle to 30 degrees; blade height can be raised to approx. 8"; can be adjusted for plowing height. Good condition. Contact 978 682-2164.
it's NOT ok to contact this poster with services or other commercial interests
PostingID:3480758036
#2 chris m ONLINE
chris m
  • 3,338 Thanks
  • 4,063 posts
Posted December 17, 2012 - 12:31 AM
Looks nice but I think is is just selling it with an adapter and not the whole 3 point. The adapter just makes it so it will hook up to a 3 point hitch tractor.
#3 Farmlife OFFLINE
Farmlife
    Tractor Whisperer
  • 1,233 Thanks
  • 1,461 posts
Posted December 17, 2012 - 04:35 AM
looks like a nice setup but I see nuthing Sears on there. The plow may be, I can't see in that close to the actual hitch/lift itself but from what I can see, it's not Sears
#4 mjodrey OFFLINE
Posted December 17, 2012 - 04:58 AM
Not a bad looking blade.
#5 KennyP ONLINE
  • 38,271 Thanks
  • 45,877 posts
Posted December 17, 2012 - 05:02 AM
The blade and hitch are Sears. May have been modified some. I have the same blade, only in a sleeve hitch version. I hope to change my blade to a Cat-0 hitch (by replacing the sleeve hitch part so it can be used both ways). That is a very heavy blade, nearly 3/8" thick!
#6 Oo-v-oO ONLINE
Oo-v-oO
  • 341 Thanks
  • 448 posts
Posted December 17, 2012 - 05:46 AM
Well... there are two three-point hitches there. One on the Deere plus the Sears hitch with handle attached.
