New Horse For Stable!
11 replies to this topic
#1 glgrumpy OFFLINE
  • 8,816 Thanks
  • 8,014 posts
Posted December 16, 2012 - 06:28 PM
Won a Commando 8 on epay for $50! Won't know what I got till I go get. It's not far from me. Is this same tractor as B-80 or smaller? The wheels looked kinda small on back.
#2 KC9KAS ONLINE
KC9KAS
  • 5,469 Thanks
  • 4,725 posts
Posted December 16, 2012 - 06:56 PM
glgrumpy's new tractor...Posted Image
#3 glgrumpy OFFLINE
  • 8,816 Thanks
  • 8,014 posts
Posted December 16, 2012 - 07:58 PM
Picture pops up Here too!!! Wierd! Thanks!
#4 LilysDad OFFLINE
LilysDad
    Anything Red . . .
  • 14,132 Thanks
  • 10,199 posts
Posted December 16, 2012 - 08:10 PM
I can't imagine being grumpy after a deal like that! My B-80 had 12"rims with smaller tires, not 26. Ummmh... maybe 23s.
#5 greggn OFFLINE
greggn
  • 3 Thanks
  • 14 posts
Posted December 18, 2012 - 08:55 PM
Should be 10 " rims on rear.
#6 glgrumpy OFFLINE
  • 8,816 Thanks
  • 8,014 posts
Posted December 19, 2012 - 07:19 PM
Got the tractor today, still on the trailer and dark, so No pix yet. Will have to start it later, needs jump. PO said it will go. Carb looks clean. One front and rear tire flat too, gotta get new front one, has big rip in it. Back one has tube, but big crack/rip on side of it also, so may be finding diff ones. 10" wheels. 8" wide tires.
#7 KC9KAS ONLINE
KC9KAS
  • 5,469 Thanks
  • 4,725 posts
Posted December 19, 2012 - 07:44 PM
You are becomming quite the WH collector!
Edited by KC9KAS, December 19, 2012 - 07:44 PM.
#8 toro520hfan OFFLINE
toro520hfan
  • 7 posts
Posted December 20, 2012 - 09:53 PM
Looks nice but is a fixer upper.
#9 glgrumpy OFFLINE
  • 8,816 Thanks
  • 8,014 posts
Posted December 21, 2012 - 08:42 PM
OH, sure! A new Owner, gonna be someone again, yeah, right! Look at me out in this weather and cold, tied up! Wa-a-a-a-a-!
#10 glgrumpy OFFLINE
  • 8,816 Thanks
  • 8,014 posts
Posted December 22, 2012 - 05:52 PM
Update! Well, got her rolled off trailer and over to garage to try to start. Rear flat took air, but front is shot. Battery not a lick of charge. Jumped it, no start action with key, durn! Bypassing to starter made it crank some. No spark tho. Looked at wiring in dash. Seemed kinda melted at switch. Finally realized there was a bypass safety switch on the brake/clutch. Pressed that, got my spark, and when cranked it popped off! Darn girl runs real nice and no smoke or nothing. Starts instantly with jumper batt. Took her for a ride some and most gears worked, but 3rd pops out instantly unless I hold lever over. Didn't make gear noises tho. Let it run awhile hoping for Batt charge, but not going to happen, it's gone! Drove her around to house garage and rolled her in for now, till xmas junk is put away and Mama want's car back in there. Runs and steers nice, even with that front flat that Stayed on wheel the whole time! :beerchug:
#11 KC9KAS ONLINE
KC9KAS
  • 5,469 Thanks
  • 4,725 posts
Posted December 22, 2012 - 06:53 PM
Good deal! Glad you got it running.
I'm sure the guys on the other forum you visit (WH's exclusive) will be able to shead some light on the transmission problem.
Sounds like that front tire is going to be a tough one to break down!
#12 Tankman OFFLINE
Tankman
  • 299 Thanks
  • 299 posts
Posted December 30, 2012 - 07:48 AM
Looks and sounds great, engine runs. I had a Commando 800, let it go to someone in "need."
Mine had (has) 10" rims on the rear, one reason for letting the Commando leave. I have a few
sets of spare 12" rims with tires mounted.
