Anyone Know What's Inside This Fitting?
4 replies to this topic
#1 ggsteve OFFLINE
ggsteve
  • 142 Thanks
  • 253 posts
Posted December 16, 2012 - 02:17 PM
I am thinking I should grease the bearings at each end of my snow thrower auger. There are no zerks anywhere on the auger or bearing. Does anyone have a snow thrower with this fitting? If you greased it can you tell me how you did it? If I take it apart are there pieces inside that I will undoubtedly lose?
While we're at it, is there anywhere else I should grease? I checked the gear box a few months ago.
#2 Toolpartzman OFFLINE
Toolpartzman
    Fun With Horsepower
  • 468 Thanks
  • 1,280 posts
Posted December 16, 2012 - 03:04 PM
Someone will know better than I, but it looks to like a low-speed floating bushing that needs dis-assembly to lube. ?
#3 MH81 OFFLINE
Posted December 16, 2012 - 03:12 PM
If its a bearing, it's probably a sealed unit. Unless they are stiff, I would leave them be.
When you have to replace them, you may be able to install a fitting and take one side of the seal out so you can grease it in the future
If it's a bushing, you will have to take it apart to properly lube. You may be able to install a fitting while you're doing it.
#4 JDBrian OFFLINE
  • 9,644 Thanks
  • 14,158 posts
Posted December 16, 2012 - 03:42 PM
Have you got a parts manual. It should give a description that would tell you if it's a bushing or a bearing. My Ariens commercial blower has bearings at the ends of the auger and I think it also has grease fittings.
#5 glgrumpy OFFLINE
  • 8,741 Thanks
  • 7,978 posts
Posted December 16, 2012 - 06:03 PM
Those are common bearings that have that sheid/mount usually on each side of the tin. The bearing is rounded and the sheild is tapered to match ad allows some movement and tightens down when bolted tight. Common item. Most are sealed bearings till you get into bigger ones. Most farm stores have those to buy in pieces. Some will also have a collar to lock the center to the shaft to make sure it moves with it. Don't think this lighter version has that. Just oil it. Looks new to me, will last long time.
