Fluid Leaking
15 replies to this topic
#1 Bob 537 OFFLINE
Bob 537
  • 68 Thanks
  • 127 posts
Posted December 16, 2012 - 10:55 AM
on my tractor i noticed where the rear end axle goes into the final drive has a small leak is this a gasket that i need or a seal if so can someone point me to the right part so i can order it thanks
#2 David Brown OFFLINE
David Brown
  • 4,510 Thanks
  • 2,424 posts
Posted December 16, 2012 - 12:55 PM
If memory serves me right (that doesn't usualy go to well) this should be a seal that can be changed from the outside IF you can get the hub off. Sorry I do not have the part number but getting the hub off can be a challenge.
#3 Ryan313 ONLINE
  • 3,366 Thanks
  • 5,231 posts
Posted December 16, 2012 - 05:12 PM
HERE is a manual that will help. I know it is for a new tractor, but the final drives are the same. What you are looking for is in part two.
  • HowardsMF155 said thank you
#4 Bob 537 OFFLINE
Bob 537
  • 68 Thanks
  • 127 posts
Posted December 16, 2012 - 06:22 PM
would it be part number 8? labeled seal
#5 Ryan313 ONLINE
  • 3,366 Thanks
  • 5,231 posts
Posted December 16, 2012 - 06:27 PM
That seal is for where the differential connects to the final drive, if I am looking at the diagram correctly. I can't find the seal that is leaking. I will keep staring at the picture... hopefully I find it!
#6 Bob 537 OFFLINE
Bob 537
  • 68 Thanks
  • 127 posts
Posted December 16, 2012 - 06:30 PM
if thats where im leaking from that would be the seal i need......right?
#7 Ryan313 ONLINE
  • 3,366 Thanks
  • 5,231 posts
Posted December 16, 2012 - 06:40 PM
Yes, but I am starting to get confused on the location of the leak. Could you take a picture?
#8 Bob 537 OFFLINE
Bob 537
  • 68 Thanks
  • 127 posts
Posted December 16, 2012 - 06:49 PM
#9 Alc OFFLINE
  • 6,887 Thanks
  • 7,461 posts
Posted December 17, 2012 - 06:58 AM
I think mine is seeping oil there too . I''l have to double check , be intrusted in how people repair that , Al
#10 Bob 537 OFFLINE
Bob 537
  • 68 Thanks
  • 127 posts
Posted December 17, 2012 - 04:05 PM
well ill let you know as soon as i find out what seal or whatever it is i need to repair it
#11 Ryan313 ONLINE
  • 3,366 Thanks
  • 5,231 posts
Posted December 18, 2012 - 07:46 AM
I have been thinking about it, and I think you will have to remove the entire final drive to replace that seal.
  • David Brown said thank you
#12 David Brown OFFLINE
David Brown
  • 4,510 Thanks
  • 2,424 posts
Posted December 18, 2012 - 08:11 AM
I agree with Ryan here. That leak is not where I thought it was. I'm afraid you have a bit of a project ahead of you.
#13 Bob 537 OFFLINE
Bob 537
  • 68 Thanks
  • 127 posts
Posted December 18, 2012 - 04:13 PM
is it that seal im thinking of labeled number 8 in the exploded diagram?
#14 David Brown OFFLINE
David Brown
  • 4,510 Thanks
  • 2,424 posts
Posted December 18, 2012 - 05:01 PM
I'm thinking it is.
  • Bob 537 said thank you
#15 Buggyman OFFLINE
Buggyman
  • 42 Thanks
  • 94 posts
Posted December 18, 2012 - 05:48 PM
I have a leak in what I think is the same spot. I contacted "Mission" about it and was told that unless it is really bad to clean the outside and swab it with silicone, Changing it is a BIG deal as it is a pressed in seal.
