2414 Tear Down
5 replies to this topic
#1 glgrumpy OFFLINE
  • 8,605 Thanks
  • 7,909 posts
Posted December 13, 2012 - 06:56 PM
Tore into PK today in sunshine! Got trans top off and loosened up some gears, got them turning . Engine was part stuck and now turning over too. Have it all apart now. Brake shaft nice and greasy/movable, the lift shaft not so good, kinda tight. A few pix.
#2 Alc ONLINE
  • 6,883 Thanks
  • 7,459 posts
Posted December 13, 2012 - 08:03 PM
That transmission looks pretty rusty hope you can get it cleaned up, at least for the gears/shafts .Is the clutch rusted fast ? Al
#3 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Looks like you made some real progress. The frame on those PK's always looks so tiny. Is it a hollow rectangular tube? It's nice to have the sun this time of year.
#4 Alc ONLINE
  • 6,883 Thanks
  • 7,459 posts
Posted December 13, 2012 - 08:09 PM
Brian , I think they can get away with a small frame is they use a torque tube driveshaft , Al
#5 Farmlife OFFLINE
Farmlife
    Tractor Whisperer
  • 1,233 Thanks
  • 1,461 posts
Posted December 13, 2012 - 08:42 PM
one more step towards the goal.....good luck, thanks for the pics
#6 glgrumpy OFFLINE
  • 8,605 Thanks
  • 7,909 posts
Posted December 13, 2012 - 09:56 PM
Yes, rectangular tubing, taller than it is wide. Pretty thick, with lots of beefed up areas with solid metals. That's what is likeable about PK, simplem metals were used to make them and you can make the same parts or similar in your own shop just buying stock metals. Most are straight parts too, no fancy bends. I built a complete three point hitch once, using another PK as a model. Could hardly tell the difference fom stock.
Think most of rust is gonna blast off real easy. Didn't really see any broken or gone teeth on gears. There was a level down inside that had a film to it, just like an old paint would have in can. Was kinda funny, had to break thru it to see bottom cluster. Must have been oild oils floating on the water?? then dried? Whatever. I tear down and blast almost everything anymore on my rebuilds, the WAY to go in my opinion. Have to go all the way down to make sure no grit in bearings and holes though. Then prime/paint stuff that needs it.
