P.t.o Kit
bolens ht20d
3 replies to this topic
#1 1967bolens collector OFFLINE
    Deceased
  • 663 Thanks
  • 1441 posts
Posted December 13, 2012 - 03:05 PM
lets say i got this p.t.o kit and 3pt can i run a regular 3pt tiller or finishing mower thats cat 0?
#2 OldBuzzard OFFLINE
OldBuzzard
    Deceased
  • 7144 Thanks
  • 4825 posts
Posted December 13, 2012 - 04:00 PM
Not unless you modified it. The rear PTO and 3-pt use the same mounting points so they can't be used at the same time.
You would be able to use pull behind implements though.
#3 1967bolens collector OFFLINE
    Deceased
  • 663 Thanks
  • 1441 posts
Posted December 13, 2012 - 05:22 PM
oh that stinks they should of made it so you could use both... well there goes that plain
#4 1967bolens collector OFFLINE
    Deceased
  • 663 Thanks
  • 1441 posts
Posted December 13, 2012 - 08:29 PM
plus i have a 2in p.t.o pump i use to irragate my garden to instead of useing a tractor i coild have in the field the 20D would be perfect. im running low pressure so. i have a few other things i can use it around the farm for
Also tagged with one or more of these keywords: bolens ht20d
