Spark Plug Thread Repair?
36 replies to this topic
#31 marlboro180 OFFLINE
marlboro180
  • 635 Thanks
  • 954 posts
Posted December 14, 2012 - 04:46 PM
Yes LD, that one is a little tougher, but TimeSert has some bigger inserts as well. Personally never had to look for anything 18mm specifically though.
BIG-SERT® OVERSIZED THREAD REPAIR KITS AND INSERTS
Used for threads which have been previously repaired and failed.
These kits will repair holes that were repaired by helicoil, perma-coil,
uni-coil, recoil or any other simular coil style insert that has failed.
  • LilysDad said thank you
#32 Ryan313 OFFLINE
  • 3,368 Thanks
  • 5,231 posts
Posted December 16, 2012 - 06:29 PM
I went back to autozone today, and got the right insert. I went with the threaded insert over the helicoil. It was VERY easy to put in and now I just have to resurface the head.
#33 HDWildBill OFFLINE
  • 8,975 Thanks
Posted December 16, 2012 - 07:12 PM
You should be back in business shortly. Glad it worked for ya.
#34 marlboro180 OFFLINE
marlboro180
  • 635 Thanks
  • 954 posts
Posted December 16, 2012 - 10:52 PM
Sweet! What system did you go with ? ( I personally hope it was the Timesert, LOL) Much better than a Helicoil fo this application...
Edited by marlboro180, December 16, 2012 - 10:54 PM.
#35 Ryan313 OFFLINE
  • 3,368 Thanks
  • 5,231 posts
Posted December 16, 2012 - 11:20 PM
I am not sure what it was, it is the one with the threads on the inside and outside. Half of the outside threads where like little teeth, and it came with this thing that you put on the insert then hit it with a hammer.
  • marlboro180 said thank you
#36 marlboro180 OFFLINE
marlboro180
  • 635 Thanks
  • 954 posts
Posted December 16, 2012 - 11:25 PM
I like hammers , LOL
#37 MH81 OFFLINE
Posted December 17, 2012 - 02:29 AM
Ryan, glad to hear you got it fixed. Hopefully, you're home free now.
Looking forward to the "I got it back together and it's running" post. :thumbs:
