Spark Plug Thread Repair?
36 replies to this topic
#16 glgrumpy ONLINE
  • 8,622 Thanks
  • 7,926 posts
Posted December 12, 2012 - 09:27 PM
Yeah, I did one of those all in one kits on a car head once. Forgot about it! It held too!
Was just coming back to say epay seller jrhaines (Good guy and cheaper than most) has a head for $20 from PK. Has one tin holding bolt broke off in it. He shows that, along with other pix of head.
#17 robert_p43 OFFLINE
robert_p43
  • 572 Thanks
  • 534 posts
Posted December 12, 2012 - 09:35 PM
I had an old moped once that ran great but would sudenly not run. Even though the plug looked good and showed good spark, I would have to put in a brand new one for the machine to run again. I carried a plug socket and new plug wherever I went. One day it happened and I could no longer tighten the spark plug. I went to NAPA and bought a kit. I remember it was easy and had me back on the road in no time. The problem I had with it was this. The "have to put in a new plug often" problem was still there, and sometimes the helicore wanted to unscrew with the plug.
#18 whst400 OFFLINE
whst400
  • 25 Thanks
  • 29 posts
Posted December 12, 2012 - 11:04 PM
First off, I've been advised that a threaded insert is much better than a helicoil. Second, I went to my lawn dealer and he repaired it for $10. Cheaper than the kit.
Excellent point! The Heli-Coil was designed to repair threads in holes where a threaded insert is not practical: ie an automotive engine head that costs considerable dollars and time to remove and replace. Most small engine heads can be removed in a very few minutes and a threaded insert and head gasket usually cost less than a heli-Coil kit. A properly installed threaded insert will almost never unscrew when removin a spark plug, unlike Heli-Coils.
#19 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 13,343 Thanks
  • 9,800 posts
Posted December 13, 2012 - 08:32 AM
There is a Loctite Red that will freeze those threads forever now.
#20 Alc ONLINE
  • 6,912 Thanks
  • 7,472 posts
Posted December 13, 2012 - 08:36 AM
I had my K301 head reapired at a machine shop I wonder how it was done now ? Always thought it was Heli-Coiled but after reading this thread not so sure , doesn't matter which ever way it's been fine for about 15 years , Al
#21 Guest_gravely-power_*
  • Guests
Posted December 13, 2012 - 10:23 AM
It also works very well on loose bearing races.
#22 marlboro180 OFFLINE
marlboro180
  • 635 Thanks
  • 954 posts
Posted December 13, 2012 - 10:29 AM
Here at the shack there is generally a spark plug thread repair once in a while. I use the Time- Sert tool I bought a couple years ago,and it has never let me down.
In general, the kit I got from the car parts store, has a few threaded sleeves ( threaded inside and out) , a ream, a tap, and an installation tool. It works great, and was fairly priced considering the money and aggrevation it has saved me ( and a couple buddies too) .
added a link : http://www.timesert.com/
This pictures repair below was a Sunday afternoon affair, and the insert wanted to walk back out of the head despite using red locktite. I then peened around the insert, and that was that.
Edited by marlboro180, December 13, 2012 - 10:38 AM.
#23 Ryan313 OFFLINE
  • 3,369 Thanks
  • 5,231 posts
Posted December 13, 2012 - 03:01 PM
I went to autozone last night, they had them but they where all metric... except one. It said it was 1/2 but it looked pretty small. Is the 1/2 the ID or the OD?
#24 DougT OFFLINE
DougT
    Dog Approved
  • 6,930 Thanks
  • 4,997 posts
Posted December 13, 2012 - 03:52 PM
The spark plug should be 14mm thread.
#25 Ryan313 ONLINE
  • 3,369 Thanks
  • 5,231 posts
Posted December 13, 2012 - 05:36 PM
Oh... maybe that is why my 1/2 tap didn't fix it! My tap and ide set only goes up to 13mm. I just figured it would be standard.
Edited by Ryan313, December 13, 2012 - 05:37 PM.
#26 LilysDad OFFLINE
LilysDad
    Millennium Falcon
  • 13,343 Thanks
  • 9,800 posts
Posted December 13, 2012 - 06:18 PM
You need to be careful of the holes left by peening. Staph bacteria can set up shop in there and eventually they will eat away at the head, weakening it.
#27 marlboro180 ONLINE
marlboro180
  • 635 Thanks
  • 954 posts
Posted December 13, 2012 - 06:55 PM
Ya, that would make things go poorly LOL. 14mm x 1.25 pitch, generally makes things in the spark plug world happy.
LD- that repair pictured above was on the ugly mower triplex beastie.... Do you think the resultant staph infection is why it looks sickly ? :-) The clumsy handed surgeon did grind away the longish insert though, assuring no interference inside the heart of the beast. ;-)
#28 xshooter OFFLINE
xshooter
  • 34 Thanks
  • 93 posts
Posted December 13, 2012 - 08:05 PM
It also works great on slightly loose splined shafts.
#29 LilysDad OFFLINE
LilysDad
    Millennium Falcon
  • 13,343 Thanks
  • 9,800 posts
Posted December 13, 2012 - 08:50 PM
I would sure take a biopsy of that head and send it to the lab. And check your health insurance.
  • marlboro180 said thank you
#30 LilysDad ONLINE
LilysDad
    Millennium Falcon
  • 13,343 Thanks
  • 9,800 posts
Posted December 14, 2012 - 11:09 AM
I have an old Wisconsin 4 hp engine that has 18mm threads. Not easy finding a kit for that! (That's the one the dealer finally fixed for me.)
