Spark Plug Thread Repair?
36 replies to this topic
#1 Ryan313 OFFLINE
  • 3,240 Thanks
  • 5,159 posts
Posted December 12, 2012 - 04:30 PM
Some may remember I asked if the heads on a K321 where interchangeable with a K301 head. The answer was maybe, there where different style heads offered. Anyway, I needed to know because I dropped the head from the '71 and messed up the spark plug hole threads. I have a few spare K301 engines and none of them have the same style head as the K321 in the '71. instead of buying another head, I think I might try to repair the threads. Has anybody tried the helicoil thread repair kits? How easy was it to put in? Any other repair kits you suggest?
#2 jms180 OFFLINE
jms180
  • 966 Thanks
  • 1,254 posts
Posted December 12, 2012 - 04:34 PM
can yout straighten the threads with a tap?
#3 Ryan313 OFFLINE
  • 3,240 Thanks
  • 5,159 posts
Posted December 12, 2012 - 04:35 PM
No, I tried that.
#4 chris m OFFLINE
chris m
  • 3,277 Thanks
  • 4,033 posts
Posted December 12, 2012 - 04:41 PM
Ryan I have not had to replace threads in a head yet. But how bad are the threads? If there not real bad you can buy a thread restorer tool at most auto parts stores. as far as being able to swap heads, I would assume the head form the K301 would fit. I know on the K241 and the K301 you can swap the heads even if there different styles. The only thing you need to make sure is that the valve heads are the same diameter on the 2 engines.
I haven't had a k321 so I am not 100% sure.
#5 Ryan313 OFFLINE
  • 3,240 Thanks
  • 5,159 posts
Posted December 12, 2012 - 04:52 PM
The valves in the k321 are the same size, In the k301 the exhaust valve is smaller; although, I might have that backwards. HERE is where we talked about it.
#6 chris m OFFLINE
chris m
  • 3,277 Thanks
  • 4,033 posts
Posted December 12, 2012 - 04:58 PM
Do you happen to have a picture of the underside of all the heads you have?
#7 Ryan313 OFFLINE
  • 3,240 Thanks
  • 5,159 posts
Posted December 12, 2012 - 05:07 PM
The only one I can take a picture of is the one with messed up threads, the others are on the engines.. According to the link in the other thread I need a third generation head, I only have first generation heads.
  • chris m said thank you
#8 chris m OFFLINE
chris m
  • 3,277 Thanks
  • 4,033 posts
Posted December 12, 2012 - 05:14 PM
If you can post a picture I can at least compare it to both of the heads I have from a K301 and k241.The ones I have are 2 different styles but they work on both engines. I have swapped them around a couple times already.
#9 HDWildBill OFFLINE
  • 8,840 Thanks
  • 8,614 posts
Posted December 12, 2012 - 05:16 PM
I'd try a thread chaser first, I fixed some really messed up threads with mine. If that doesn't fix it get a machine shop to put a helo-coil in it.
#10 MH81 ONLINE
  • 28,024 Thanks
  • 28,957 posts
Posted December 12, 2012 - 05:31 PM
Several years ago, Dad had a Heli put in the head of the Teccy on his log splitter. It's held fine, but he had some $ it.
Another option he almost went with was buying a plug with the next size base & drilling and tapping to that. He decided that would be "Option B" if the Heli didn't pan out.
#11 JRJ OFFLINE
JRJ
  • 876 Thanks
  • 1,170 posts
Posted December 12, 2012 - 05:49 PM
It been many years since I messed with a Heli coil but as I remember them, it is like a kit, you get a special tap and the tool to install the coil along with the coil and the instruction and it wasn't hard to do.
Dick
#12 glgrumpy ONLINE
  • 6,813 Thanks
  • 6,608 posts
Posted December 12, 2012 - 06:14 PM
Yeah, like JR said, there is a Kit with drill, tap, insert tools and inserts for plugs. The kit is not ALL the helicoil stuff, just for the one or two sizes you are working on. Nice to get the correct bit, as they are odd sizes. The tap in kit makes bigger threads, then the heli-coil part brings it back to standard when inserted. Doesn't have to be Heli-coil brand either. Ones I've gotten from my shop were a diff brand, but still good quality. Don't by Chinese junk one!
Always thought many heads interchanged, only needed to have correct bolt pattern. Didn't know of any valve clearance issues?
#13 coldone OFFLINE
coldone
  • 1,634 Thanks
  • 1,671 posts
Posted December 12, 2012 - 06:24 PM
Advance auto sales the one I used. It came with a reamer/tap combo and several different size inserts. It worked good (keep the reamer striaght) and the inserts fit well. I dont have much run time on the engine but it looks like it will hold up fine.
Costed around $20
#14 LilysDad ONLINE
LilysDad
    Crazy about GTTalk
  • 10,096 Thanks
  • 7,930 posts
Posted December 12, 2012 - 06:30 PM
First off, I've been advised that a threaded insert is much better than a helicoil. Second, I went to my lawn dealer and he repaired it for $10. Cheaper than the kit.
#15 boyscout862 ONLINE
  • 10,049 Thanks
  • 7,677 posts
Posted December 12, 2012 - 06:34 PM
There are other type kits too. The one I will use on my K341 will be the K-D insert tool. It reams and threads at the same time. Then just screw in an insert with some loctite on its od and you are done. The kit comes with the tool and about 6 inserts. I will take the head of first and set it up on my drill press to get accurate alignment.
