Is This Normal?
vickers hb112 reduction gearbox
11 replies to this topic
  • 2,331 Thanks
  • 1,498 posts
Posted December 11, 2012 - 06:56 PM
I just split the reduction gearbox on my HB112 so I could replace the drive/neutral shift stem. Now, when I turn the wheels, there is silence at first but then there is what I assume is gear noise. Are both the silence & noise normal? If not, what should I be looking for?
http://youtu.be/ZSsnAOWK7Lc
#2 olcowhand ONLINE
  • 41,131 Thanks
  • 31,413 posts
Posted December 11, 2012 - 07:01 PM
Sounds like it's coming from the planetary differential on the right axle???? Kind of appears like the noise starts when the 2 rear wheels start turning at different speeds. May be time to take a look inside the diff.
  • Michiganmobileman and New.Canadian.DB.Owner have said thanks
#3 MH81 OFFLINE
Posted December 11, 2012 - 07:05 PM
Boy does that sound like a gear hitting the case...
I don't have one of these, but I would say no, that's not normal.
#4 chris m ONLINE
chris m
  • 3,338 Thanks
  • 4,063 posts
Posted December 11, 2012 - 07:20 PM
One question, I have never had one of these but did it do this after you replaced the shaft? It sounds like you are in between gears? like something is not adjusted correctly and 2 gears are just barley touching one another?
I could be way off. but the sound seems real familiar to me.
I just figured I would throw another option your way. But Daniel and Alan's suggestions sound like they could be correct also.
#5 HDWildBill OFFLINE
  • 8,975 Thanks
Posted December 11, 2012 - 08:25 PM
Like Alan it sounds like the one of the gears is hitting something. What ever it is it takes it a second or two get to a point where it can not move and the gear starts riding over it. Like Daniel said sounds like time to open her up.
#6 GTTinkerer OFFLINE
GTTinkerer
    GT Tinkerer
  • 1,163 Thanks
  • 1,331 posts
Posted December 11, 2012 - 08:41 PM
Sounds like maybe one of the spider gears is missing some teeth and they get to just the right spot and one starts riding over the other. Like most other posters I believe it is time to take a look inside.
Edited by GTTinkerer, December 11, 2012 - 08:42 PM.
#7 New.Canadian.DB.Owner OFFLINE
  • 2,331 Thanks
  • 1,498 posts
Posted December 12, 2012 - 07:03 PM
Thank you for all your input. It wasn't the spider gears (see video). I re-split the gearbox & examined the gears, shafts & housing for damage. There wasn't anything obvious. I then messed around with the axle tube and, well, the noise disappeared (see video).
Edited by New.Canadian.DB.Owner, December 12, 2012 - 07:04 PM.
#8 MH81 OFFLINE
Posted December 12, 2012 - 08:37 PM
Glad to hear (or not hear) it.
What was it that you messed with?
#9 New.Canadian.DB.Owner OFFLINE
  • 2,331 Thanks
  • 1,498 posts
Posted December 12, 2012 - 08:44 PM
The axle tube. Basically, I pulled on the right rear wheel to get a better view of the guts. When I pushed it back into place, the noise was gone.
#10 HDWildBill OFFLINE
  • 8,975 Thanks
Posted December 12, 2012 - 09:00 PM
Glad you got it fixed.
#11 8tyman8 OFFLINE
8tyman8
  • 415 Thanks
  • 731 posts
Posted December 18, 2012 - 12:46 PM
Where did you get those tires ! i didn't know they sold a R4 in 12"s
#12 Cat385B ONLINE
    HAZMAT CAT
  • 13,974 Thanks
  • 10,002 posts
Posted December 18, 2012 - 01:07 PM
Carlisle makes an R4 in 23 x 8.5 x 12:
Also tagged with one or more of these keywords: vickers, hb112, reduction gearbox
