some customers jd 420- 314- 216 parts freshly coated and more to follow
22 replies to this topic
#1 thecoater OFFLINE
thecoater
  • 13 Thanks
  • 111 posts
Posted August 25, 2010 - 02:16 AM
here some pics from the last 2 days -I hope you John Deere guys appreciate the hardwork the owner/s is putting into there tractors
and of course the hardwork I put into refinishing them LOL I have more pics to load tomorrow I just am tired from today
moderators if this is in the wrong spot please let me know
#2 mjodrey OFFLINE
Posted August 25, 2010 - 04:29 AM
Looks good.
#3 olcowhand OFFLINE
  • 37,710 Thanks
  • 30,338 posts
Posted August 25, 2010 - 09:04 AM
Question about powder coating....does the powder paint flow level to fill tiny pits & such? Not knowing about coating much, I do know they have to be baked, so if it doesn't flow level, then what is used to fill pits that powder will stick to and not be destroyed by the baking process?
BTW...nice work!
#4 thecoater OFFLINE
thecoater
  • 13 Thanks
  • 111 posts
Posted August 25, 2010 - 09:12 AM
powder itself wont fill pits sometimes it only makes them look worse ,they do make a powder fill primer that is amazing ,you can apply as many coats as you need until its perfect then shoot your color
you need to bake/cure everycoat before more can be applied so it can build and fill but the results are worth it for someone going for the perfect look-the cost for perfection can easily get out of hand if the part is real bad to start with
when powder cures it shrinks making it go into any valley or divit etc,when using the fill primer treat it almost like bondo sand out imperfections and apply more if needed
I can shoot powder so it cures anywhere from 1-4 mils no different then liquid paint just alot more durable when applied correctly
Edited by thecoater, August 25, 2010 - 10:01 AM.
#5 Bolens 1000 ONLINE
  • 13,918 Thanks
  • 17,710 posts
Posted August 25, 2010 - 05:31 PM
Those parts Look REALLY Good!!!
:dancingbanana:
#6 brzezinski01 OFFLINE
brzezinski01
  • 4 Thanks
  • 73 posts
Posted August 25, 2010 - 10:20 PM
how does powder coating looks compared to paint? is it a smoother finish? I know its way more durable. just wondering if you came out smoother.
#7 thecoater OFFLINE
thecoater
  • 13 Thanks
  • 111 posts
Posted August 25, 2010 - 11:10 PM
click on the 1st pic it dont get any smoother than that! there 314 side covers.
not really sure what you mean otherwise,have you looked at all the orange peel on all the new cars and trucks the clear coat is the only thing that makes them smooth
applied correctly with the proper tools I can and do acheive better finishes than any wet painter can !and I dont have to spend 10hrs buffing
the pic of the 420 is the owner of the 216 parts. I did the 420 last fall for him,I did everything but the hood
these are show quality finishes the 420 below and the 216 above received a primer, a color, and clear 3 stages
the 420 in the 1st post just got color and clear
heres an honest question for you guys ,how much do you think I charged for the parts in the 1st post its not all the parts
each tractor consisted of 2 side covers,seat brackets,big pan ,steering tower ,and battery tray ,grill ,
they were blasted and chemically pretreated its part of the price
Edited by thecoater, August 25, 2010 - 11:39 PM.
#8 mjodrey OFFLINE
Posted August 26, 2010 - 04:45 AM
That 420 looks some good.I never realized there was a clear powder coat.
#9 thecoater OFFLINE
thecoater
  • 13 Thanks
  • 111 posts
Posted August 26, 2010 - 12:23 PM
yes sir ,they make a flat ,mid,and high gloss clear and some with flake,they have over 20,000 colors available not to mention colors that can be made by minipulating transparent colors over each other
and I can get colors custom matched and made
#10 mjodrey OFFLINE
Posted August 26, 2010 - 12:28 PM
That is good information to know.
#11 caseguy OFFLINE
Posted August 26, 2010 - 05:57 PM
I don't know much about powder coating...aside from the remarkable results!! :thumbs: I assume that this is not a "do-it-yourself" surface treatment. Is there a lot of expense involved in the necessary equipment?
#12 thecoater OFFLINE
thecoater
  • 13 Thanks
  • 111 posts
Posted August 26, 2010 - 07:44 PM
they do sell hobby equipment ,but its not all there is to it ,sandblasting a part only cleans it -it does nothing to surface treat the substrait(steel,alum,etc)
so unfortunatly theres alot of hacks doing a half ass job
-if your having something powder coated make sure you ask how there going to prep -blasting to white metal and properly applied phoshate -if they dont have that go elsewhere some use a spray bottle if they do RUN FAST---I have a 5 stage's in my washline
my price is more reasonable than you may think -when compared to other forms of metal finishing and the longevity of properly applied powder coat- if someone is restoring any type of farm equipment powder is the only way to go -its all they use nowadays, they just dont do a good job
and just like your signiture says
If something is worth doing, It's worth doing right.
I would post more pics of other things but dont want the moderators to be upset with non tractor items
#13 Bolens 1000 ONLINE
  • 13,918 Thanks
  • 17,710 posts
Posted August 26, 2010 - 08:34 PM
If you have one or two pics your more than welcome to post them. I like the looks of this powder coating.... If you have alot of pics you can post them in the "off topic" forum. I'm sure others will like to see as well :thumbs:
#14 thecoater OFFLINE
thecoater
  • 13 Thanks
  • 111 posts
Posted August 26, 2010 - 09:36 PM
thanks for the kind words from everyone,I will post more photos in the off topic section
#15 mikebramel OFFLINE
mikebramel
    Ron Paul
  • 177 Thanks
  • 1,009 posts
Posted September 04, 2010 - 08:59 PM
those are beautiful
id guess 150 for the seat pan?
