Basic Wiring
2 replies to this topic
#1 mixedbreed96 OFFLINE
  • 11 Thanks
  • 167 posts
Posted December 10, 2012 - 11:24 AM
Looking for the easiest way to wire a 5 post ignition to a 12hp briggs vertical shaft motor, motor has two wires running out from the flywheel, one red, one black, will be using a 3 post starter solenoid and headlights, thanks in advance, Ryan.
#2 WNYTractorTinkerer ONLINE
    Tinker Master
  • 10,661 Thanks
  • 5,855 posts
Posted December 10, 2012 - 11:41 AM
Depends on what equipment your tractor has..
Neutral Safety Switch?
PTO Safety Interlock?
Electric or Manual PTO?
RIO PTO cutoff?
What style Briggs is it?? Magneto With W/O points?
What style Alternator or does it have a Starter/Generator? How many AMPS will it put out?
So many little details will determine how to properly wire your machine.
Also, Different switches switch different connections even thought he switches look identical. You have to be careful or you could cook a wire or even worse!
So if you want worthwhile help, you will need to furnish all of the details and even a picture or two can help us help you more..
#3 DougT OFFLINE
    Dog Approved
  • 6,994 Thanks
  • 5,020 posts
Posted December 10, 2012 - 12:55 PM
If you check the Briggs manuals on the site, one has the charging system diagrams. There are 3 different styles if I remember right depending on wire colors and sizes. That wil probably be the first thing you need to figure out. I think they show basic wiring in there also.
  • ducky said thank you
