Found
Ff 20 Parts
13 replies to this topic
#1 KennyP OFFLINE
  • 31,351 Thanks
  • 41,564 posts
Posted December 10, 2012 - 06:21 AM
I am looking for the Hydro fan, the knob for the position control, and a right hand grille brace so far. May be adding to the list. PM me if you have any of these.
#2 JDBrian OFFLINE
  • 9,593 Thanks
Posted December 10, 2012 - 07:29 AM
Kenny, if that tractor is using the Sundstrand 15 hydro you may be able to use fans from MF, JD or other tractors using the same setup.
#3 KennyP OFFLINE
  • 31,351 Thanks
  • 41,564 posts
Posted December 10, 2012 - 08:01 AM
That's what I am hoping, just need some specs from one of those fans to see if it will work. This one is 7" OD, I need to get the ID measurement. It is an Eaton 11 Hydro though. Maybe a Ford fan will fit it?
#4 olcowhand ONLINE
  • 36,869 Thanks
  • 30,149 posts
Posted December 10, 2012 - 12:01 PM
Likely identical, as well as fans from an MTD990 series and more.
#5 JDBrian OFFLINE
  • 9,593 Thanks
Posted December 10, 2012 - 02:49 PM
I have the 317 fan in the next room and measured it. It's 6" but since it's the rear PTO version it attaches to a rubber isolated coupler. Half of that coupler is still on the trans. I looked up the parts online and it looks like the shaft is .670? diameter. The fan is secured with a 1/4" drive pin. I'm going to guess this isn't compatible with anything else in the tractor universe.
#6 KennyP OFFLINE
  • 31,351 Thanks
  • 41,564 posts
Posted December 11, 2012 - 05:31 AM
After searching around, I have the new part # from Ford (which is a direct fit) The fan is now an LB702301 and lists for $44. I'm going to try the old part # (JAC335219) first and see what happens.
#7 baerpath OFFLINE
baerpath
  • 314 Thanks
  • 514 posts
Posted December 11, 2012 - 11:33 AM
You might try a Wheel Horse for the fan they used the Eaton 11 also
#8 KennyP OFFLINE
  • 31,351 Thanks
  • 41,564 posts
Posted December 11, 2012 - 06:30 PM
Which Wheel Horse are we talking about here? I'm not familiar with them.
#9 skyrydr2 OFFLINE
  • 3,673 Thanks
  • 3,304 posts
Posted December 11, 2012 - 07:07 PM
Any of the Hydros they made except the Big D series had a belt driven Eaton mounted sideways .But I don't think the fans were the same, those were built into the pulley.
#10 baerpath OFFLINE
baerpath
  • 314 Thanks
  • 514 posts
Posted December 11, 2012 - 08:22 PM
The fans are seperate and held to the pulley with a 1/4 inch bolt on the C series through the 520's.
#11 KennyP OFFLINE
  • 31,351 Thanks
  • 41,564 posts
Posted December 12, 2012 - 05:51 AM
Here's the best pic I can get of where the fan goes:
#12 skyrydr2 OFFLINE
  • 3,673 Thanks
  • 3,304 posts
Posted December 12, 2012 - 08:22 AM
Kenny tne fan is held on to the driveshaft yoke with a cir-clip and should have a spring behind it for tension. This is how it is on the Fords anyway, but if you have u-joints it will be held in place with either a roll pin or grub screw that is long and sticks out to act as a pin. The latter is what I believe you have on the FF.
#13 KennyP OFFLINE
  • 31,351 Thanks
  • 41,564 posts
Posted December 12, 2012 - 08:37 AM
I think you are on the right track, Keith. Since there is not anything left of the original, it's hard to see what it is supposed to be like.The cir-clip is still there, though. Just have to get a fan and see what works.
#14 KennyP OFFLINE
  • 31,351 Thanks
  • 41,564 posts
Posted April 05, 2013 - 09:09 AM
Parts found!
Also tagged with one or more of these keywords: Found
