Modifying Cast Iron Wheel Weights
81 replies to this topic
#76 Oo-v-oO ONLINE
  • 341 Thanks
  • 448 posts
Posted April 07, 2013 - 11:07 AM
I'm late to this party, but just take them to a machine shop and have them bored out on a lathe already!
Whatever small amount they would charge would have already paid for your drill press and angle grinder...
#77 DH1 ONLINE
    Electric Tractors
  • 5,302 Thanks
  • 5,579 posts
Posted July 24, 2013 - 08:02 PM
Today after work I decided to try something different, I took my 7" angle grinder with a 4-1/2" grinder disc and ground out the inside of the other wheel weight that I haven't done anything with.
20 minutes later it was big enough to fit over the hub, I spent 5 more minutes grinding to give it some more clearance.
I now have 2 wheel weights that can be bolted to the rim on the inside that fit over the hubs.  :thumbs: :rocker2: :dancingbanana: :rolling: :bounce:
Why I didn't do this in the first place :wallbanging:
What I started with yellow weights
First one
2nd one
Best fastest tool to do the job
All that's left to do now is paint and install.
  • olcowhand, Gtractor, Alc and 2 others have said thanks
#78 DH1 ONLINE
    Electric Tractors
  • 5,302 Thanks
  • 5,579 posts
Posted August 11, 2013 - 01:29 PM
Finished finally I did it.
They ended up weighing 46 and 47lbs.
Painted and mounted on the inside.
And these when painted will go on the outside for a total of 96 and 97lbs each wheel.
Edited by DH1, August 11, 2013 - 02:48 PM.
  • olcowhand, KennyP and bgkid2966 have said thanks
#79 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted August 11, 2013 - 01:49 PM
Very nice Doug. I use Wheel Horse cast iron wheel weights on the inside of the Caterpillar. So far two years and Steve (Caseguy) still hasn't noticed, but don't tell him that. :D
Edited by wvbuzzmaster, August 11, 2013 - 01:50 PM.
  • DH1 said thank you
#80 KennyP ONLINE
  • 39,078 Thanks
  • 46,286 posts
Posted August 11, 2013 - 02:03 PM
Looking good, Doug! Nice to have weights in there!
#81 olcowhand ONLINE
  • 41,843 Thanks
  • 31,623 posts
Posted August 11, 2013 - 02:49 PM
Gonna make for a heavier tow coming down for plow day!   :D
#82 Robert Webb OFFLINE
Robert Webb
  • 920 Thanks
  • 434 posts
Posted August 12, 2013 - 02:28 PM
Wont be any worse than the 430 being towed UP there for plow day.............last time I plowed with it, it had 70 lb starter weights on each wheel, and 2 50 pounders bolted on the outside of the starter weights and each tire was filled with antifreeze as well.  I was plowing some hard ground and needed the traction.  There were a couple of times that it would actually pick the front end of the 430 up off the ground..............talk about adding PUCKER FACTOR..........lol   I will probably just mount the starters and bring the others along "Just In Case"
