Modifying Cast Iron Wheel Weights
81 replies to this topic
#61 IamSherwood OFFLINE
  • 8,391 Thanks
Posted December 29, 2012 - 09:18 AM
How are you making out here Doug?
Are you gettin er done?
#62 DH1 ONLINE
DH1
    Electric Tractors
  • 5,271 Thanks
  • 5,567 posts
Posted December 29, 2012 - 09:20 AM
I need to buy the grinding wheel, until I get nothing is happening with this task.
#63 Alc ONLINE
  • 6,885 Thanks
  • 7,460 posts
Posted December 29, 2012 - 09:28 AM
Doug, wouldn't a carbide burr like these work faster for you ? Al
http://www.carbidepl...ategory_s/3.htm
#64 DH1 ONLINE
DH1
    Electric Tractors
  • 5,271 Thanks
  • 5,567 posts
Posted December 29, 2012 - 09:33 AM
I have some steel ones like those, haven't tried them, I figured that a larger diameter would work better but???
#65 olcowhand ONLINE
  • 41,166 Thanks
  • 31,423 posts
Posted December 29, 2012 - 09:36 AM
The larger diameter, the more they can grab & take you on a trip.  Little ones can be a handfull.
#66 IamSherwood OFFLINE
  • 8,391 Thanks
Posted December 29, 2012 - 09:44 AM
It's such a dusty job, and that crap is hard to get rid of. Are you sure your neighbour
doesn't have a lathe?
#67 DH1 ONLINE
DH1
    Electric Tractors
  • 5,271 Thanks
  • 5,567 posts
Posted December 29, 2012 - 09:47 AM
 No lath, I'd have to go to a machine shop for that, all I have are simple tools.
#68 IamSherwood OFFLINE
  • 8,391 Thanks
Posted December 29, 2012 - 09:56 AM
:rolling:  :rolling:  :rolling:
You'll love this ad!!!!!
I just stumbled across this, looking for something else.
http://ontario.kijij...QAdIdZ438794693
#69 olcowhand ONLINE
  • 41,166 Thanks
  • 31,423 posts
Posted December 29, 2012 - 09:59 AM
Worth about $25!  :rolling:   Nobody would buy it for anything but parts.  I did get a kick out of his ad though!  :D
#70 Alc ONLINE
  • 6,885 Thanks
  • 7,460 posts
Posted December 29, 2012 - 10:01 AM
Doug , I wanted you to see this book site for ideas but noticed that it's shutting down , too bad because I picked up a few books from it and I'm sure others here did too and we'll miss it , Al
http://www.lindsaybks.com/
#71 DH1 ONLINE
DH1
    Electric Tractors
  • 5,271 Thanks
  • 5,567 posts
Posted December 29, 2012 - 10:06 AM
The text of the ad
Date Listed 09-Dec-12 Last Edited 23-Dec-12 Price $225.00 Address Athens, ON K0E, Canada
southbend workshop metal lathe model b ,bed lenght is 31.5 inches.  . all the extra gears and collets with it as well .ok we'll trythis way then $225 price is firm and not negotiable now.i've already reduced it by 150.if it isn't worth that ,i'l cut it into peieces and throw it out for scrap myself just for spite so all you idiots that seem to think it's worth 20 -50 bucks can all go f--- yourself. just a hint also ,you do actually have to show up to look at it if you want it.
Visits: 1021
Edited by DH1, December 29, 2012 - 10:07 AM.
#72 coldone OFFLINE
coldone
  • 1,651 Thanks
  • 1,679 posts
Posted December 29, 2012 - 11:44 AM
Why cant you use milling bits in the drill press? A rough end mill or a boring head taking very light passes at slow speed shoud be able to clean up the holes. I understand drill press are not mills but you are not trying to do precison work either.
#73 DH1 ONLINE
DH1
    Electric Tractors
  • 5,271 Thanks
  • 5,567 posts
Posted April 06, 2013 - 05:08 PM
Update
Well it's been a while since I did anything with these and now I have a new idea for them.
While working on them I managed to burn up the motor in my drill press and 1 angle grinder.
It was suggested to me that I should cut them in have and mount them on the inside like Massey 2 piece weights can.
My vote is cut the weights in half so they will go over the hub and then bolt them right to the wheel like they are one piece. Cast cuts very easy with a sawzall or hack saw.
like this ( )
Kriss I should of listened to you, that would of been the best way for me to do since I don't have a set of torches or a lathe and don't know anything about milling tools.
Any way now I'm stuck with 1 crappy looking weight and need to decide what to do.
Recently I picked up a set of Massey MF7,8 factory wheel weights with the intention of using them for front wheel weights for 8" rims, but they only weigh 19lbs and don't fit, need to be modified which will make them lighter.
Comparison to JD front wheel weights. 19lbs to 32lbs
I found that they fit inside the wheel weights that I was trying to modify.
My idea now is to weld the 2 weights together to make 1 heavy weight that mounts on the outside.
Should be 65 to 70 lbs when together. The inside one will have to be spaced out a couple inch's to
clear the axle shaft and should end up looking something like this. All painted Red.
What do you guys think?
Edited by DH1, April 06, 2013 - 05:09 PM.
  • Gtractor said thank you
#74 IamSherwood OFFLINE
  • 8,391 Thanks
Posted April 06, 2013 - 05:25 PM
I think you've been playing with your weights. :D
Personally, I wouldn't weld them together. Even though, they would
look good, and serve their purpose, in doing so, you'd be putting a couple
of nice collectibles to death. Many would give their left arm to have
those as part of their collection.
You're wanting to add weight, to the front, for plowing dirt?
What about fluid in the tires, and suitcase weights? And/or making
some concrete weights?
#75 DH1 ONLINE
DH1
    Electric Tractors
  • 5,271 Thanks
  • 5,567 posts
Posted April 06, 2013 - 05:33 PM
I could just fill the centers with cement instead of the MF weights.
Anybody want to buy the MF7,8 weights for what I paid for them? $40. for the pair.
The Original Idea for this thread was to mount 2 sets of weights to each rear wheel 1 inside 1 outside for more weight on the rear of the MF16.
The JD front wheel weights are going on the MF16 also.
Tires will get filled also, all 4.
Edited by DH1, April 06, 2013 - 05:34 PM.
