Modifying Cast Iron Wheel Weights
81 replies to this topic
#46 chris m OFFLINE
chris m
  • 3,287 Thanks
  • 4,038 posts
Posted December 23, 2012 - 07:45 PM
Wow you sure put some work into that! Congrats on getting it done. :thumbs:
#47 MH81 OFFLINE
  • 28,446 Thanks
  • 29,126 posts
Posted December 23, 2012 - 07:57 PM
Those masks look like you were cleaning a chimney while grinding. Yech.
Glad you got thru, looks like you found the solution to the problem, even if it is time consuming.
#48 wvbuzzmaster ONLINE
  • 4,554 Thanks
  • 7,372 posts
Posted December 23, 2012 - 08:51 PM
Well, I wouldn't want to lose that much weight to get over a hub, How much do the once 53 pound weights weigh now?
Great work on it, I just use Wheel Horse wheel weights for my inside weights on the Caterpillar (don't tell Steve, I don't think he knows yet LOL)
#49 DH1 ONLINE
DH1
    Electric Tractors
  • 4,762 Thanks
  • 5,374 posts
Posted December 23, 2012 - 09:22 PM
Right now it weighs 47lbs
The other one that 50lbs unmodified.
#50 massey driver ONLINE
massey driver
  • 1,174 Thanks
  • 1,480 posts
Posted December 23, 2012 - 09:56 PM
You've been busy thats for sure,projects like this are usually time consuming,but you do get a good feeling about doing stuff yourself.Good job,you'll even feel better once the other one is completed.Can't wait to see them mounted on the tractor.Larry
#51 DH1 ONLINE
DH1
    Electric Tractors
  • 4,762 Thanks
  • 5,374 posts
Posted December 23, 2012 - 10:01 PM
What kind of a power tool can be used to grind them?
Something like an angle grinder that is not angled.
The drill press just doesn't have enough RPM or torque to turn a 4" to 5" disk, an angle grinder can do the job much faster but you just can't get at what you want to grind.
Something like a high power, high rpm hand held drill would go it.
#52 MH81 OFFLINE
  • 28,446 Thanks
  • 29,126 posts
Posted December 23, 2012 - 10:34 PM
So, what you're looking for is a die grinder on steroids? Hmmm, I've seen 120* grinders, but not 180*
EDIT: I found one, but It's a little more than the $90 hole saw :rolling:
http://www.gettoolsd...r-750-watt.html
  • DH1 said thank you
#53 DH1 ONLINE
DH1
    Electric Tractors
  • 4,762 Thanks
  • 5,374 posts
Posted December 23, 2012 - 10:48 PM
If I bought the hole saw I don't think my drill press has enough *** to turn it.
That tool you list would be much better at doing the job but $$$
I have a high power 1/2" drill but it only turns 450rpm.
#54 Texas Deere and Horse OFFLINE
  • 14,472 Thanks
  • 15,392 posts
Posted December 23, 2012 - 11:44 PM
Doug, We use grinder cones to clean up holes that wheels and right angle disc grinders won't fit into.
Here is a photo of a few, most welding supply houses carry them.
  • DH1 and KennyP have said thanks
#55 KennyP ONLINE
  • 31,338 Thanks
  • 41,554 posts
Posted December 24, 2012 - 05:43 AM
What is the thread size on these Brian? Guess I could google it! 5/8"-11 sound right?
Doug, I have a DeWalt 1/2" hammer drill. It has a hi/lo speed switch. No Load speed is like 2700 rpm. And you can turn the hammer off.
#56 Texas Deere and Horse OFFLINE
  • 14,472 Thanks
  • 15,392 posts
Posted December 24, 2012 - 10:15 AM
Yes Kenny, they are 5/8" - 11 thread just like your grinding discs.
Sorry, I should have posted that.
#57 DH1 ONLINE
DH1
    Electric Tractors
  • 4,762 Thanks
  • 5,374 posts
Posted December 24, 2012 - 06:55 PM
Found these online, there made for right angle grinders and I think I can get in deep enough going at it from both sides to do the job.
I have a 4-1/2" and a 7" angle grinders which are way more powerful than any drill I have.
What do you think?
http://www.grainger....0071&sst=subset
  • Texas Deere and Horse and KennyP have said thanks
#58 KennyP ONLINE
  • 31,338 Thanks
  • 41,554 posts
Posted December 24, 2012 - 07:11 PM
Those should do a good job. Just be sure to clamp the weight down so when grinding it's easier to apply pressure where needed.
#59 MH81 OFFLINE
  • 28,446 Thanks
  • 29,126 posts
Posted December 24, 2012 - 08:36 PM
Keep the extra handle on that grinder, good gloves on, eye/ear protection, leather chaps, and do your stretching exercises first.
You know how a stone can grab and next thing you know, your grinder is running down the piece of steel?  Well, imagine that in a circle.
Doug, we recently missed out on a video of a run away engine because of camera failure, be sure to set yours up in a safe spot so we don't miss out
smiley_spinning.gif_480_480_0_64000_0_1_
#60 DH1 ONLINE
DH1
    Electric Tractors
  • 4,762 Thanks
  • 5,374 posts
Posted December 24, 2012 - 08:42 PM
My #1 rule is NO ACCIDENTS, do what ever you can to prevent them.
Been hurt to many times over the yrs and learned this the hard way.
Edited by DH1, December 24, 2012 - 08:43 PM.
  • MH81 and IamSherwood have said thanks
