Mtd 990 3pt Hitch Install
mtd 990 farm king 3pt hitch
16 replies to this topic
#16 HALFSCALE OFFLINE
HALFSCALE
  • 515 Thanks
  • 537 posts
Posted May 23, 2013 - 08:02 AM
You should be ok, most hydraulic oil is straight 30w, and that includes ATF, the differences are in the additives. Automatics in vehicles use a friction clutch and the additives in ATF are for those needs, but in the sundstrands and eatons it is a piston type. I have seen in cubs and deere's that using what they call for makes a difference for the better , but in my eatons, it doesn't seem to matter ,I haven't had any issues with either ATF or hydraulic fluid
  • Utah Smitty and VTXrider have said thanks
#17 VTXrider OFFLINE
VTXrider
  • 535 Thanks
  • 392 posts
Posted May 23, 2013 - 08:29 AM
I have been using hydraulic oil in one of the 990s and straight 30w engine oil in my original 990 transmission. Although I have changed the oil and filter only twice that I can remember. It stays clean and clear. The main concern is overheating. The cooling fan can break from a stick or from age. I have replaced it one time.
Edited by VTXrider, May 23, 2013 - 08:31 AM.
  • Utah Smitty said thank you
Also tagged with one or more of these keywords: mtd 990, farm king, 3pt hitch
