Bush Hog Seal # Needed
4 replies to this topic
#1 york0060 OFFLINE
york0060
  • 320 Thanks
  • 151 posts
Posted August 24, 2010 - 08:23 AM
i am trying to find out what a part number is for a axle seal (rear outside)on a HD-12 Bush Hog, and where do i ad and check hyd. fluid on the tractor real axle? i am assuming you add till it runs out of the fill neck on the center line of the axle.Bush hog 4.jpg
#2 olcowhand ONLINE
  • 42,898 Thanks
  • 31,941 posts
Posted August 24, 2010 - 10:15 AM
Yes, you fill till the neck is level full. Axle seal is #53056, but that's the original Bush Hog part #, so may not be a valid number. I can't find any seal info with that number. You'll likely have to take the old seal to a bearing/seal supply business & match one up.
#3 york0060 OFFLINE
york0060
  • 320 Thanks
  • 151 posts
Posted August 24, 2010 - 02:59 PM
thanks for the info. do you know what hyd fluid is recommended, i am not to familier with hyd fluid.
#4 olcowhand ONLINE
  • 42,898 Thanks
  • 31,941 posts
Posted August 24, 2010 - 03:13 PM
Just use Dexron III transmission fluid. Do NOT use hydraulic oil!
  • york0060 said thank you
#5 york0060 OFFLINE
york0060
  • 320 Thanks
  • 151 posts
Posted August 24, 2010 - 03:19 PM
thanks for the heads up.
