Missed A Bush Hog For Free On Cl *edit, Bought It!
98 replies to this topic
#61 olcowhand ONLINE
  • 41,148 Thanks
  • 31,416 posts
Posted January 06, 2013 - 09:30 PM
It looks like 1 brush is wore out in the cap, am I seeing that right?
Looks that way to me.  Time for new brushes, and clean the armature pickups.  The windings on the armature look to have been hot at one time, but may still be fine.  Between each armature pickup contact & the armature shaft, there should be no connection, so test before spending a dime.
#62 Titus OFFLINE
Titus
    Bush Hog Hoarder
  • 1,836 Thanks
  • 2,331 posts
Posted January 06, 2013 - 09:34 PM
What would I use to clean these?
#63 chris m OFFLINE
chris m
  • 3,338 Thanks
  • 4,063 posts
Posted January 06, 2013 - 09:41 PM
I like to use a fine scotch brite to clean them. I use the red ones myself. green will work also. Fine emery will work just go easy.
Like Daniel said I would test it with the meter to make sure each section isn't shorting out.
#64 Titus OFFLINE
Titus
    Bush Hog Hoarder
  • 1,836 Thanks
  • 2,331 posts
And when I need to buy these things, do you have part numbers or a website where I can order them? Thanks
#65 Titus OFFLINE
Titus
    Bush Hog Hoarder
  • 1,836 Thanks
  • 2,331 posts
Posted January 06, 2013 - 09:42 PM
Now that it's late LOL I'll check for voltage tomorrow.
#66 chris m OFFLINE
chris m
  • 3,338 Thanks
  • 4,063 posts
Posted January 06, 2013 - 09:46 PM
You will check it using OHM's scale on the meter. I am sure one of us will be around when you got to test it. Good luck. Parts I am not sure. Daniel may know?
#67 Titus OFFLINE
Titus
    Bush Hog Hoarder
  • 1,836 Thanks
  • 2,331 posts
Posted January 06, 2013 - 09:54 PM
Doh OHMs sorry...tired. Would you happen to have a diagram depicting the terminology for this starter. I'm not to familiar with these armature pickups, etc and a photo with things labeled would help a ton if I am looking for parts.
#68 olcowhand ONLINE
  • 41,148 Thanks
  • 31,416 posts
Posted January 06, 2013 - 09:59 PM
I'll do digging for parts sources when I get the time.  The commutator pickups we refer to are the squares on the end of the armature where the brushes run.  Between each of these & the armature shaft, using an ohmeter, should be no continuity, or in other words, an open circuit.  If any of these show a connection to the shaft, then it is toast & replacing the entire starter would be the best & almost only way to go.
#69 Titus OFFLINE
Titus
    Bush Hog Hoarder
  • 1,836 Thanks
  • 2,331 posts
Posted January 06, 2013 - 10:00 PM
Thank you Daniel!
#70 Titus OFFLINE
Titus
    Bush Hog Hoarder
  • 1,836 Thanks
  • 2,331 posts
Posted January 07, 2013 - 06:57 PM
Would anyone happen to know the model number for this starter? It looks like this model I found on ebay:
http://www.ebay.com/...=item3ccdd84085
Just so when I find out if this is bad or not, I can just order a used or new one. Thanks
#71 chris m OFFLINE
chris m
  • 3,338 Thanks
  • 4,063 posts
Posted January 07, 2013 - 07:09 PM
I am not 100% sure Pete. I would have to look up your engine model if I had it.
But I do believe Daniel has been down this road and knows what starter you need.
#72 olcowhand ONLINE
  • 41,148 Thanks
  • 31,416 posts
Posted January 07, 2013 - 07:18 PM
Here's a brand new one with warranty, shipping included for $58.40.  This fits all the 6hp TEC engines, 16 tooth.
http://www.ebay.com/...=item519aeec7d3
  • chris m said thank you
#73 olcowhand ONLINE
  • 41,148 Thanks
  • 31,416 posts
Posted January 07, 2013 - 07:20 PM
Starter # 35765A is what it calls for, but other starter #'s do also work.  The one above definitely should fit perfectly.
  • Titus and chris m have said thanks
#74 Titus OFFLINE
Titus
    Bush Hog Hoarder
  • 1,836 Thanks
  • 2,331 posts
Posted January 08, 2013 - 10:48 AM
Well do I feel silly. I had a dream last night that it was a bad battery. So I brought the starter into work and bench tested it to a fresh battery. Works fine! So my battery was bad. :( But that solves that problem! Thanks for all the help guys.
Will update when I get the starter back in and new battery installed.
#75 Titus OFFLINE
Titus
    Bush Hog Hoarder
  • 1,836 Thanks
  • 2,331 posts
Posted January 08, 2013 - 04:50 PM
Well I feel siller now. It bench tests fine, but when I reinstalled it just now with a brand new battery, it buckles and doesn't want to turn. I was able to move it with my finger. It wants to move but it's tired. I'm just going to order a new one and scrap this one.
