* * * * * 1 votes
Clothes Washer Busted/fixed....nope, Busted!
80 replies to this topic
#1 olcowhand OFFLINE
  • 44102 Thanks
  • 32301 posts
Posted December 05, 2012 - 11:49 AM
I commented in another thread how our spin cycle quit on our clothes washer. Teresa had a load in it when it failed to spin. I rocked & rotated the drum & it then started working, but slower than normal, and with a loud screeching sound. Well, Teresa found the problem. After removing the clothes, then looking for why there were some mineral particles in the clothes, she discovered one of my tiny screwdrivers stuck through a basket hole just under the edge of the agitator. I pulled the agitator, removed the screwdriver, and she works like new again. My 50yr old screwdriver got it's tip worn a bit, but all is good!
  • MH81, twostep and LilysDad have said thanks
#2 Dieselcubmike OFFLINE
Dieselcubmike
  • 1345 Thanks
  • 1529 posts
Posted December 05, 2012 - 11:59 AM
Glad its fixed! Never thought something like that would cause a problem lol
#3 mjodrey OFFLINE
  • 2375 Thanks
  • 13481 posts
Posted December 05, 2012 - 12:03 PM
Good to hear you got it fixed.
#4 tinner OFFLINE
tinner
  • 504 Thanks
  • 1561 posts
Posted December 05, 2012 - 12:20 PM
Linda always complains about things I leave in pockets. So far nothing has stopped the washer from working properly. I do have some funny looking pink briefs and tee shirts from when I did some clothes for her though.
#5 MH81 OFFLINE
  • 30054 Thanks
  • 29761 posts
Posted December 05, 2012 - 12:21 PM
I've been guilt of not checking my pockets before, but I don't think I've ever left anything that big in there.
#6 MH81 OFFLINE
  • 30054 Thanks
  • 29761 posts
Thanks for not posting pictures...
  • tinner said thank you
#7 chris m OFFLINE
chris m
  • 3350 Thanks
  • 4069 posts
Posted December 05, 2012 - 12:38 PM
I sure am glad it was something simple! That is the 1st time I have ever seen that happen.
#8 HDWildBill OFFLINE
  • 8994 Thanks
  • 8664 posts
Posted December 05, 2012 - 01:07 PM
This is an on going thing in our house. The other day Sherry came out of the laundry room to give me a nice clean socket. :D
Glad you got it fixed and it didn't cause any major damage.
Yes this is one time No Pic's are required, Tinner! :smilewink:
#9 Cat385B OFFLINE
    Tractorfanatics.com
  • 14750 Thanks
  • 10288 posts
Posted December 05, 2012 - 01:41 PM
Daniel, from here on out just use the bench grinder to get a decent tip back on the flat heads. I'm not sure where on the World Wide Web you read to use a washing machine, but I assure you the bench grinder is faster.
First, an automated milking parlor. Now, automated milling. What's next? Robotic paint booth?
Yep, just let the camera remain at idle. No need to throttle 'er up for that one. :thank_you:
Edited by Cat385B, December 05, 2012 - 01:44 PM.
  • tinner and KC9KAS have said thanks
#10 A.C.T. OFFLINE
A.C.T.
    Another Classic Tractor
  • 2365 Thanks
  • 2496 posts
Posted December 05, 2012 - 01:55 PM
  • JakeKuhn, KC9KAS and jd.rasentrac have said thanks
#11 olcowhand OFFLINE
  • 44102 Thanks
  • 32301 posts
Posted December 05, 2012 - 02:11 PM
OOPS.....I spoke too soon! The washer is now leaking like crazy. I took it apart & the plastic drum was cut by the screwdriver all the way through about an inch or so, and deep for another 7 or 8". I may be able to repair it, and if not, I'll see what the part costs.
#12 GTTinkerer OFFLINE
GTTinkerer
    GT Tinkerer
  • 1189 Thanks
  • 1342 posts
Posted December 05, 2012 - 03:22 PM
Daniel,
Same thing happened to me but with a drywall screw a few years back. Pulled the drum, put on some original JB weld, put it back together and let it dry overnight. It has been good to go since then.
#13 HDWildBill OFFLINE
  • 8994 Thanks
  • 8664 posts
Posted December 05, 2012 - 03:33 PM
I hate it when that happens! You think you escaped a major problem only to find out oop's no you didn't. :mad2: Hope you can fix it Daniel. You could also try plastic welding.
#14 jd.rasentrac OFFLINE
jd.rasentrac
  • 4979 Thanks
  • 4413 posts
Posted December 05, 2012 - 03:57 PM
In more then 30 years living together, Doris, my wife, or I found all the coins, nails, screws, knives or tools I wear in my pockets - we always wondered, how this could happen. But we never damaged a washing machine (knock on wood)!
Edited by jd.rasentrac, December 05, 2012 - 03:58 PM.
#15 daytime dave OFFLINE
  • 5478 Thanks
  • 6780 posts
Posted December 05, 2012 - 04:22 PM
I hope you can get the leak fixed Daniel. It would be a shame to wake up the Maytag man.
