* * * * * 4 votes
The Adventures Of My New Hat
5525 replies to this topic
#3676 olcowhand ONLINE
  • 42,895 Thanks
  • 31,937 posts
Posted March 10, 2016 - 02:33 PM
If I had one of those Eaton's I'd mail you a pin, but I don't have any Eaton's on the place these days.
  • Craig. said thank you
#3677 UncleWillie ONLINE
  • 16,251 Thanks
  • 8,969 posts
Posted March 10, 2016 - 04:00 PM
Last one
  • MH81 and Craig. have said thanks
#3678 UncleWillie ONLINE
  • 16,251 Thanks
  • 8,969 posts
Posted March 10, 2016 - 07:09 PM
My body is asking for a break.
12800280_922259621176559_896696678408845
After Heath's speech therapist left we loaded up and headed off.
CherryBerry was low of gas so we stopped at a Race-Trac to fill up. I didn't realize how low it was and I don't think I could have made it to another one.
We went inside to get a drink and soon found out that the credit card system was having a moment. I had to wait. It took them about 20 minutes to get it rebooted. New software. They said the old software worked perfectly.
Once we finally had fuel (14.8777 gallons in a 15 gallon tank) we headed up to get the last tractor. It was a Troy-bilt that still had the tag on the ignition switch. IT was hardly used.
We stopped at Lowe's and I got a Porter Cable cordless drill and impact set. then off to the car wash to blast the dust and crud off the TB.
We headed home and I got to work. I pulled the Power King out and it fired right up. Something in the wiring is messed up and the electric clutch and the electric lift are not working. I am going to list it as is tomorrow. My hands are hurting too bad to mess with wiring. I did verify that the clutch will engage if you jump a wire to it. It will not take power from its switch though.
By the time I was finished tinkering with the PK Steph got home.
We tried to start the TB, but it wouldn't start. I acted like the engine was frozen. I couldn't turn it. Once I verified that the starter did work I put a breaker bar on the engine. It tried to turn. I looked under it and found that the deck is frozen. Since it was used so little it has probably been sitting for long enough for the belt to have stuck to the pulleys.
Once I took the deck belt off it did start.
Then I decided to go for broke and see why the JD had not throttle response. The short answer is I didn't hook it back up. Duuh.
Once I fixed my mistake it came down off the stand. It will do a wheelie. Kind of fun to play with. I decided to list it for sale as is. If it doesn't sell I will paint it and put a new hood on it and lest it for more.
The guy gave me a bagger that he said fit the TB. It didn't. It did however fit the Huskey LE after I turned the bottom part around the right way.
Tomorrow I have to see if the Huskee will start and get the deck on the TB freed up. Hopefully I will only need a spindle and a blade for the Huskee.
I also have to find out if the Murray will start with a new starter on it.
  • MH81, wvbuzzmaster, Craig. and 1 other said thanks
#3679 UncleWillie ONLINE
  • 16,251 Thanks
  • 8,969 posts
Posted March 10, 2016 - 07:11 PM
Well, you rain on my parade then rain some more don't you LOL>
  • olcowhand, wvbuzzmaster, Craig. and 1 other said thanks
#3680 olcowhand ONLINE
  • 42,895 Thanks
  • 31,937 posts
Posted March 10, 2016 - 07:54 PM
Hey, I'm doing my best!   :smilewink:   I did start a "Wanted" thread hoping someone has the pin you need.
#3681 UncleWillie ONLINE
  • 16,251 Thanks
  • 8,969 posts
Posted March 10, 2016 - 08:20 PM
I see that. I wonder why there is not reply for it.
At this point I would buy a whole charge pump if it was priced right.
  • olcowhand said thank you
#3682 DougT OFFLINE
DougT
    Dog Approved
  • 7,110 Thanks
  • 5,075 posts
Posted March 10, 2016 - 08:50 PM
Does anybody have a part number for the pin? I looked in the service manual and couldn't even find a good pic. what's so special that it can't be made? I'm sure it has to be super hard but is there anything else? Any good picture of the part with dimensions?
  • KennyP and UncleWillie have said thanks
#3683 olcowhand ONLINE
  • 42,895 Thanks
  • 31,937 posts
Posted March 10, 2016 - 09:06 PM
I couldn't find part #'s or a good pic of the pin either.  What I have seen looks as though it's cylindrically shaped to where it lays flat in a rounded cut on both the shaft & carrier.  But yes, if we had dimensions, I'm sure it could be fashioned from a large needle bearing.
#3684 KennyP OFFLINE
  • 40,857 Thanks
  • 47,081 posts
Posted March 11, 2016 - 06:57 AM
I have a complete Eaton/Peerless from a Ford YT tractor. Hate to part it though.
#3685 UncleWillie ONLINE
  • 16,251 Thanks
  • 8,969 posts
Posted March 11, 2016 - 11:32 AM
All I can tell you is it is pretty small. It fell out and we never saw it. I have thought of trying to find a drill bit that is the right size and taking it down to my friends shop to get him to make me something. I would be afraid of the bit shattering or something stupid if I used a cut off piece of one.
KennyP if you just surrendered an FF to me it would solve a lot of problems. LOL
  • olcowhand and KennyP have said thanks
#3686 olcowhand ONLINE
  • 42,895 Thanks
  • 31,937 posts
Posted March 11, 2016 - 12:03 PM
In diagrams, it appears only about 1/4" long by maybe 3/16" thick.
#3687 DougT OFFLINE
DougT
    Dog Approved
  • 7,110 Thanks
  • 5,075 posts
Posted March 11, 2016 - 12:09 PM
I wonder if you could make it out of a piece of steel key stock and then heat it and quench to harden? they also make a roundstock I think is called drill rod that is hard and polished but it is round. You could always grind it flat.
#3688 MH81 OFFLINE
  • 29,978 Thanks
Posted March 11, 2016 - 12:30 PM
Trying to visualize this, is the cut round or flat or some of both?
#3689 UncleWillie ONLINE
  • 16,251 Thanks
  • 8,969 posts
Posted March 11, 2016 - 12:50 PM
From what I can tell it is perfectly round. I contacted Eaton a while back and they have no records of it and no part numbers. The joys of having an old machine.
Edited by UncleWillie, March 11, 2016 - 12:51 PM.
#3690 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,450 Thanks
  • 4,571 posts
Posted March 11, 2016 - 01:45 PM
I have been looking too, and dont see a reference for the carrier charge pin in here.
