Anyone Have A Sears 917.253311 Dozer Blade?
sears dozer blade
15 replies to this topic
#1 MH81 OFFLINE
Posted December 03, 2012 - 07:02 PM
Picked one up with my 18/6. It's missing a couple of parts.
If anyone has some rudimentary dimensions of part numbers 15, 17, 11 in the following diagram, that would be swell.
Thanks.
#2 rwolf15241 OFFLINE
rwolf15241
  • 1 Thanks
  • 10 posts
Posted December 05, 2012 - 06:45 AM
I have the Dozer blade from the Sears SS 16/ GT 18 Pittsburgh, PA 15241, and tons of other parts
#3 KennyP ONLINE
  • 38,191 Thanks
  • 45,842 posts
Posted December 05, 2012 - 06:59 AM
Welcome to the forum. I saw your FF Wanted ad. Great folks on here.
#4 stripmine OFFLINE
stripmine
  • 36 Thanks
  • 29 posts
Posted January 01, 2013 - 02:19 PM
Thanks.
If you don't have them already, here are some pictures that may help. look closely at the pictures for the measurements, since i was using the 1 foot mark on the tape as a starting point.
The main handle is 36" long, with a 4" 90 degree bend on the end. Total length of 3/8 rod needed is 40" for the handle.
XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
the 4" bend on the upper end of the rod.
XXXXXXXXXXXXXXXXXXXXXXXXXXXXXx
4" flat stock on lower end of rod, for connecting the unlocking chain. notice the slight bend in it. that's factory. This piece is just flat stock, 1/8" thick, 3/4" wide & 4" long with a 3/8" hole on either end. It's welded to the control rod and the release chain hooks in the other hole with an S hook.
The Swivel bracket on the handle, it fits loosely on the rod, and is held in place by the 2 welded washers above and below it.
My upper holder, ( #17) is homemade from an eye bolt, but this should help with the size.
Lastly, I the chain # 11 is less than a foot, get a short length of sash chain ( flat chain) at Home Depot, and play with the length
DSCF3577_zps853ded18.jpg.
Hope this helps.
Dave
Edited by MH81, January 24, 2014 - 07:50 PM.
  • MH81, iron Mike and chris m have said thanks
#5 chris m ONLINE
chris m
  • 3,338 Thanks
  • 4,063 posts
Posted January 01, 2013 - 02:32 PM
Thats great Dave! You went above and beyond on this! I am sure the pictures and measurements you have given is even better than Alan could have imagined getting :thumbs:
  • stripmine said thank you
#6 MH81 OFFLINE
Posted January 01, 2013 - 07:08 PM
Absolutely tops!  Thank you Dave.
I hope you didnt go thru as many hoops as it looks like you did to get those.
The manual gave me a broad overview, these pics complete the picture.
:thank_you:
#7 stripmine OFFLINE
stripmine
  • 36 Thanks
  • 29 posts
Posted January 01, 2013 - 07:12 PM
:thank_you:
no Problem.  I actually took the pictures back in October, for someone else missing the same pieces. The blade is sitting in storage, all I did was snap a few pictures real quick.  No trouble at all.  I'm glad that they will be of some help.
Dave
ADDED
If you need any more pictures or measurements, just let me know.
Edited by stripmine, January 01, 2013 - 07:13 PM.
  • MH81 and chris m have said thanks
#8 MH81 OFFLINE
Posted February 11, 2013 - 07:52 PM
Dave
ADDED
Got a chance to make use of your measurements. Almost done with the construction phase :thumbs:
One question if you have time, what is the degree angle twist from the handle to the piece welded on the end? In other words, if the handle is flat on the floor, how far off the floor is the end of the flat bar?
Thanks in advance.
#9 stripmine OFFLINE
stripmine
  • 36 Thanks
  • 29 posts
Posted February 11, 2013 - 10:04 PM
Thanks in advance.
I won't be able to make it up to check the exact degree of twist on the handle, until this weekend.  I'm gonna say it's around 30 degrees, upward with the handle flat on the floor, but that's a guess. That's about what it looks like in the first picture also.
Looks like you've got an excellent start on the handle, it looks better than the factory piece. :thumbs:
  • MH81 and iron Mike have said thanks
#10 MH81 OFFLINE
Posted February 11, 2013 - 10:12 PM
No hurry, I can even make an educated guess once I get it on the machine. I won't be able to work on it until Sunday anyways.
#11 MH81 OFFLINE
Posted February 16, 2013 - 08:21 PM
I had only a few minutes of "Me and my junk" time today. Decided to work on the rear support piece that is missing from this.
Started earlier today with a piece of 5/16" rod. Measured overall expected length
Then I found a pin that was the size I wanted for the inside hole.
Now somehow I lost the next 3 pictures... I will have to describe as I can... You have seen a torch before...
You will have to use your
I heated the rod and bent it around the pin. When I was happy, I let it cool and then heated and turned the whole circle so it looked more like the end of an eye bolt than a letter p.
Then I made a bracket to mount it to the tractor and welded that to the rod.
A little sand paper, some satin black, and...
#12 KennyP ONLINE
  • 38,191 Thanks
  • 45,842 posts
Posted February 17, 2013 - 07:24 AM
I would say you did a great job on it, but the pics are a bit dark and the black paint kind of hides it all. Could we get a couple pics with more light please? Otherwise, it sounds like you got-R-dun!
#13 MH81 OFFLINE
Posted February 17, 2013 - 09:09 AM
Yeah, I was trying to take them in the headlights with the IPAD. Sorry, I tried.
#14 KennyP ONLINE
  • 38,191 Thanks
  • 45,842 posts
Posted February 17, 2013 - 09:18 AM
Head lights don't do much for pics. I'll let ya slide right now!
#15 MH81 OFFLINE
Posted February 17, 2013 - 11:37 PM
I got another pic or two of the upper bracket etc. this time in the garage...
Anyways, I really don't like the lower arm for the l-r adjustment. Keeps wanting to bind on the U bolt. I am going to live with it for now... But I see a different & upgraded control arm in the future.
