Bolens Switches
bolens surburban st series st140
4 replies to this topic
#1 Love2Tinker OFFLINE
Love2Tinker
  • 1 posts
Posted December 03, 2012 - 02:35 PM
I have a 1988 Bolens ST140 Hydro.
My issue is figuring out where the switches are and either replacing them or troubleshooting them.
I can't get my lawn tractor to turn over what so ever.
#2 mjodrey OFFLINE
Posted December 03, 2012 - 02:41 PM
Welcome to the forum.Glad to have you with us.
May be a solenoid problem.Or a bad ground.
Edited by mjodrey, December 03, 2012 - 02:41 PM.
#3 bhts OFFLINE
bhts
  • 1,464 Thanks
  • 2,161 posts
Posted December 03, 2012 - 03:08 PM
Welcome to GTtalk. As for the switches there should be three of them. One on the brake pedal inside the frame, one on the seat and one on the hydro handle under the dash.
As Maynard said also check the solenoid and clean connections and it may also be the a bad key switch.
Also the pto switch will not let the tractor start if it is on or not working right.
Edited by bhts, December 03, 2012 - 03:09 PM.
#4 MH81 OFFLINE
Posted December 03, 2012 - 07:04 PM
:welcome: to GTTalk, glad you're getting some assistance.
#5 KC9KAS OFFLINE
KC9KAS
  • 5,324 Thanks
  • 4,670 posts
Posted December 03, 2012 - 07:56 PM
:welcometogttalk:
Do you have a multi-meter that you could use to check the switches?
If you don't have one, you better get one, because you will need one for trouble-shooting.
Also tagged with one or more of these keywords: bolens, surburban, st series, st140
