Sweating my butt off, Fans are on in the shop, and A/C on in the house.
Drag link should be here Friday, worked on finding the slow leak in the rear tire. While spinning the tire I noticed that the "00" grease has soaked into the axle and loosened the rim, it came off easily. Used a mix of Dawn and water in a spray bottle to locate the leaks. It took 14 plugs to stop all the small punctures. I need to buy another jumbo pack of plugs for the other 3 tires, but they are not as bad as this one. I hate slime, Tubes are useless here, and the tire is still in good shape. (other than looking like a porcupine). For the engine, I think the source of the engine crud is coming from the back plate. I found a new gasket for it, so it will get replaced when I drain the oil.
