Kt17 Engine Tin Fit M18?
2 replies to this topic
#1 rustyoldjunk OFFLINE
rustyoldjunk
    Has anybody seen my coffee ?
  • 2,643 Thanks
  • 1,318 posts
Posted December 02, 2012 - 05:21 PM
I asked in the wheel horse forum but it might get more traffic here.Does anyone know if the flywheel shroud tin from a KT17 will fit on a kohler 18hp magnum horizantal crankshaft engine ?
#2 chris m OFFLINE
chris m
  • 3,341 Thanks
  • 4,065 posts
Posted December 02, 2012 - 05:31 PM
I did an image search and it looks like they are different. http://www.bing.com/...CDD90F40B4B19FB
http://ts4.mm.bing.n...&h=141&c=7&rs=1
I hope this helps. Maybe someone else will have better info for you.
#3 Bmerf OFFLINE
Bmerf
  • 1,796 Thanks
  • 1,466 posts
Posted December 02, 2012 - 09:53 PM
While I'm not 100% sure, after comparing the service manuals found here: http://www.kohlereng...oductMatrix.htm
The heads appear to be identical as well as the crankcase torque sequence, I believe they are the same, but I don't have the 2 motors in question to compare first hand. Maybe someone else will have more information.
Edited by Bmerf, December 02, 2012 - 09:56 PM.
