PTO flywheel trouble
5 replies to this topic
#1 onan302 OFFLINE
onan302
  • 4 Thanks
  • 64 posts
Posted August 22, 2010 - 09:38 PM
The spring loaded PTO flywheel engagement has alan screws so that you can remove it. i unscrewed these alans and it just wont come off my kohler 12hp crank.
#2 tractormike OFFLINE
tractormike
  • 172 Thanks
  • 1,488 posts
Posted August 23, 2010 - 08:02 AM
Did you check to see if there was a second set of allen screws in each threaded hole? If I remember there was a second set screw to lock the first set screw in place.
#3 anixon92 OFFLINE
anixon92
  • 18 Thanks
  • 51 posts
Posted August 25, 2010 - 09:32 AM
here is a site page. Cub Cadet FAQ
there are 2 alan set screws in each hole. you have to remove all 6 screws.
#4 mjodrey OFFLINE
Posted August 25, 2010 - 09:41 AM
anixon92:welcometogttalk:glad to have you here.
#5 olcowhand ONLINE
  • 42,900 Thanks
  • 31,942 posts
Posted August 25, 2010 - 03:39 PM
Yep, double stacked in each hole. The last ones are pointy to lock behind the roller bearing.
#6 onan302 OFFLINE
onan302
  • 4 Thanks
  • 64 posts
Posted August 26, 2010 - 10:49 PM
thanks alot guys i ended getting it off. someone tried to drill through one of the allen screws and it was wedged to the crank. i just had to pry it off.
