Good Work Table Salvaged From Scrap...
9 replies to this topic
#1 twostep OFFLINE
twostep
    Rockstar
  • 1,970 Thanks
  • 2,528 posts
Posted December 01, 2012 - 11:58 PM
A friends work was going to scrap out a rack that was used to hold flat bed press dies in so I called dib's and here it is being turned into a usable and mobile work bench. The top and bottom panels were made from welded 1/8"x1.5"x1.5" angle with 2" square tubing for the posts. let me tell you, it was HEAVY.
First I cut the bottom portion off so that I could handle the two halves (no chance of being able to wrestle the whole thing at once). I flipped the bottom part up and proceeded to grind all of the welds off.
Lots-o-grinding! A few taps with the cold chisel and the angle steel started popping off.
After I got the bottom part taken apart I sleeved the inside of the legs, put the bottom back on and welded it up. Now I have a very stout and mobile work bench. I wouldn't be scared to park one of my tractors on this thing. Top is 36" high and about 47" x 49". To boot, I ended up with about 120' of angle left over to use on other projects. Now all I need is a piece of 3/4" plywood to use as a shelf on the bottom.
Edited by twostep, December 02, 2012 - 12:00 AM.
  • MH81, KennyP, tractorgarden and 1 other said thanks
#2 tractorgarden OFFLINE
tractorgarden
    Junk Whisperer
  • 1,294 Thanks
  • 1,443 posts
Posted December 02, 2012 - 12:04 AM
Good deal, that will make a great work station. Shawn
#3 MH81 OFFLINE
Posted December 02, 2012 - 12:24 AM
Now that's a nice bench. Nothing like a good shop addition for the low, low price of $0.
Good save.
#4 mjodrey OFFLINE
Posted December 02, 2012 - 05:23 AM
That should make a nice work bench.
#5 KennyP ONLINE
  • 37,511 Thanks
  • 45,514 posts
Posted December 02, 2012 - 05:34 AM
Great use of the bench. Plus some extra angle to boot.
#6 ducky OFFLINE
  • 1,982 Thanks
  • 4,103 posts
Posted December 02, 2012 - 06:18 AM
That's going to make a darn nice work bench. And of course the price is right.
Sent from my XT907 using Tapatalk 2
#7 jms180 ONLINE
jms180
  • 1,480 Thanks
  • 1,549 posts
Posted December 02, 2012 - 08:40 AM
very nice will make a good work bench
#8 HDWildBill OFFLINE
  • 8,975 Thanks
Posted December 02, 2012 - 10:31 AM
Nice addition to the shop and a great price as well.
#9 UncleWillie OFFLINE
  • 15,535 Thanks
  • 8,710 posts
Posted December 02, 2012 - 05:22 PM
Nice workbench.
#10 twostep OFFLINE
twostep
    Rockstar
  • 1,970 Thanks
  • 2,528 posts
Posted December 02, 2012 - 08:28 PM
thanks, there should be enough angle to build my wagon and a couple other things I've been planning.
