* * * * * 1 votes
Kenny's Road Trip
85 replies to this topic
#46 KennyP ONLINE
  • 38,414 Thanks
  • 45,945 posts
Posted December 02, 2012 - 08:39 AM
I need to look into that, Brian. There is a tube coming up the back with a cap on it. But the tube looks old and may have a crack in it. You can see part of it in the 8th pic I posted.
I have downloaded the owners manuals we have in for the FF's. Need some time to study them. Wish they were a bit better, kind of hard to read them. I was hoping someone had a good copy we could replace at least one of them with.
This has the Eaton 11/Peerless combination in it. Do any of the JD's have this combo?
#47 skyrydr2 OFFLINE
  • 3,908 Thanks
  • 3,411 posts
Posted December 02, 2012 - 09:11 AM
What's that rig have for a trans ? It looks like a Peerless/ Eaton unit ? If so its almost the same as the 195. I'm not sure if it has outboard brakes lie the 195 .
Edited by skyrydr2, December 02, 2012 - 09:14 AM.
#48 KennyP ONLINE
  • 38,414 Thanks
  • 45,945 posts
Posted December 02, 2012 - 09:39 AM
Keith, look at my last post. (Eaton11/Peerless)
I just got approved in the Yahoo FF Forum. I am raiding the files. Found a great Owners/Parts manual for the FF20. Plus some other info, like this:
I will get these things uploaded as soon as I can. Manual is already uploaded.
#49 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted December 02, 2012 - 11:23 AM
Kenny, I am just now seeing this thread, and all I have to say is that is a great looking beast of a tractor. Great score and I hope you have a lot of fun with it.
#50 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted December 02, 2012 - 05:33 PM
On the JD's 300's, which use Sunstrand transmissions, there is a tube that connects from a low point in the transmission and goes through what looks like a fuel filter then back in at the top. The tube also acts as a site glass for checking fluid level. The fuel filter needs to have a small hole (1/16") drilled through the outside casing to vent pressure in the trans. If you order the 10$ JD part it has the hole. The PO replaced the filter with a standard one but didn't know about the vent. An easy fix once I figured out what was going on. I'm not sure how the FF is vented but there needs to be one somewhere to relieve pressure in the trans.
#51 KennyP ONLINE
  • 38,414 Thanks
  • 45,945 posts
Posted December 02, 2012 - 05:53 PM
It's supposed to have one back there on that tube. But the tube has a couple holes in it right now, so it's venting. I'll get into that when I change fluid and filter.
#52 KennyP ONLINE
  • 38,414 Thanks
  • 45,945 posts
Posted December 03, 2012 - 04:44 AM
I found this pic that shows the same setup I have. So now I am befuddled. Unless there is another vent under there somewhere, I don't see one here. Guess I'll have to look a bit deeper.
#53 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted December 03, 2012 - 06:00 AM
Kenny, I think Daniel is familiar with the Eaton hydro and he would know how they are vented.
#54 KennyP ONLINE
  • 38,414 Thanks
  • 45,945 posts
Posted December 03, 2012 - 06:19 AM
I forgot to add the pic above.
#55 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted December 03, 2012 - 11:16 AM
Kenny, it doesn't seem right that the tubing is exposed unprotected like that. Does the manual have a picture of the rear end showing that. Not familiar with the Eaton hydro but the level of fluid looks very high to me. I haven't looked at the manuals you uploaded.
#56 skyrydr2 OFFLINE
  • 3,908 Thanks
  • 3,411 posts
Posted December 03, 2012 - 03:28 PM
They are vented at the fill point. No other place in or on the trans axle to vent.
#57 Cat385B ONLINE
    HAZMAT CAT
  • 13,974 Thanks
  • 10,004 posts
Posted December 03, 2012 - 03:55 PM
All the pics I can find on the great googly search show the sight tube exposed on the rear. :wtf:
#58 KennyP ONLINE
  • 38,414 Thanks
  • 45,945 posts
Posted December 03, 2012 - 05:53 PM
That is not my tractor, but mine is just like it. The manual shows something totally different. I haven't looked real close at the plug to see if it may have a small hole in it. I do plan to change the fluid and filter soon. It has the spin on type filter, but that has a dent in it. I cannot see any fluid in the tube like that pic has. Plus I need a new piece of tubing. I'm not sure when I may get to this, work goes on.
#59 JDBrian OFFLINE
  • 9,624 Thanks
  • 14,150 posts
Posted December 03, 2012 - 07:24 PM
I believe that on the JD 318 there is a small fitting that is actually a vent. I think it uses a similar Peerless 2 speed axle. I'm used to the older Dana /Sunstrand setup in the 314/317 which have the site tube inside the frame.
#60 KennyP ONLINE
  • 38,414 Thanks
  • 45,945 posts
Posted December 03, 2012 - 07:30 PM
Thanks, Brian. I just need time to look things over more. Maybe this weekend.
