Performance Anxiety Or Just Too Darned Cold?
#1
OFFLINE
Posted November 30, 2012 - 06:07 PM
But in any event, I pulled the throttle out about 1/3 and had the choke on full to try and start it. At first, it tried to fire right up and started running very slowly with the choke on. I pushed the choke in halfway as it was trying to run and it continued on for about 10 seconds or so until it finally died. I tried cranking it with half choke for a bit and it didn't sound like it wanted to do anything. So, I pulled the choke out all the way again and tried cranking it over and it sputtered for a bit and tried to start again, but it ran for about 10-15 seconds on half choke again and it sounded like it was dying again, so I pulled the choke out all the way again for a sec and then tried pushing it in and the engine just didn't want to run, so it died on me again. When I went to crank it over again, I couldn't get anything out of it at all. I was cranking it over for a good 20 minutes (off and on again of course and I never cranked it for longer than 15-20 seconds at a time). I tried full choke, half choke, and no choke and nothing seemed to make a difference. I finally gave up and did some trim work with my push mower (which I thankfully brought over) and did what I could for today and then left to go back home.
But, here is the strangest part of all. After I get back home and start to unload the trailer, I figure I'll try starting the Bolens 850 one last time as I didn't want to have to push it off the trailer by hand. I cranked it over a bit and still nothing, it didn't even sound like it wanted to start. So, I grabbed a can of carb cleaner spray to try spraying in the intake just to see if that would make any difference. A little spritz of carb cleaner later and with the choke on full, it started right up no problem! I let it idle for a few minutes and drove it right off the trailer. So why the heck didn't it want to run earlier? Was the carb flooded perhaps from choking it too long or something? Is there maybe an issue with my fuel line where it's not quite getting enough gas to start it when it is so cold out? I never had any issues with it starting when it was warmer out over the summer. Any other ideas? I just want to be sure this isn't going to be an ongoing problem as winter approaches and I want to use it to plough driveways with.
#2
OFFLINE
Posted November 30, 2012 - 06:16 PM
- wawcub47 said thank you
#3
ONLINE
Posted November 30, 2012 - 06:33 PM
#4
ONLINE
Posted November 30, 2012 - 06:39 PM
I'd watch using starting fluid. If so, use sparingly.
I'm not a big fan of the stuff either and use Carb cleaner instead.
From time to time that will happen on some of my Tractors and they need a little carb cleaner to get going again. It could be a number of things such as a small spec of debris in one of the carb ports that needs to work its way though.
Do you have a screen on your shutoff valve?
- MailmAn said thank you
#5
OFFLINE
#6
OFFLINE
Posted November 30, 2012 - 07:21 PM
I think so. It's kinda hard to look down in the gas tank though to really check it out, but I think there is some kind of screen or filter at the bottom of the tank where the gas inlet/shutoff is. I know there is really no gas filter in the fuel line though. The fuel line kinda has me a bit concerned due to its age and it looks cracked on the outside from age and the rubber dry rotting a bit. It doesn't leak though for now (and as long as I don't touch it either, I'd assume...). If I mess with it at all, I'd just end up having to replace it all as I wouldn't reuse it in the condition it is in.
#7
OFFLINE
Posted November 30, 2012 - 07:36 PM
#8
OFFLINE
Posted November 30, 2012 - 08:47 PM
I will second that! You might try some fuel drier in the tank. If ice it could have warmed up enough to loosen the ice by the time you used the starting fluid. Back in the late 50/s and early 60,s we used starting fluid a lot in cold Iowa winters.I wonder if you got some ice in the fuel or lines/carb and it eventually thawed or worked it's way through.
There were always stories floating around about the rods broke and in extreme cases cranks blown out the bottom and even heads blown off. If you do use it use it sparingly!
Remember thats a small displacement engine it does not take much ether to reach a critical and possibly terminal overload.
Edited by JD DANNELS, November 30, 2012 - 08:55 PM.
#9
OFFLINE
Posted November 30, 2012 - 09:03 PM
At the end of the day, it had dried out enough so that your spark was back to we're it should be.
I would inspect the wires for corrosien especially at the ignition switch.
I think if it were fuel related, it would have continued to run rough after starting .
Joe
#10
OFFLINE
Posted November 30, 2012 - 11:13 PM
Then don't. Replace it. Fuel line is inexpensive. The fuel that we are allowed to purchase today is nothing like the fuel the old lines were designed to carry. Change the line and know for sure this was not the problem.... I'd just end up having to replace it all as I wouldn't reuse it in the condition it is in.
PS. This past summer an old line caused a fire on one of my machines, luckily had water handy. Whoops, water will not put out a gas fire, had to watch and wait, while trying to keep everything from going up in flames. Luckily only lost the plastic gas tank. On my engines, if the line looks bad, it is bad and will be replaced.
#11
OFFLINE
Posted December 01, 2012 - 09:10 PM
