Ford Lgt100 Heavy Frame Lift Hook For Mower
ford lgt lift hook
29 replies to this topic
#16 skyrydr2 OFFLINE
  • 3,909 Thanks
  • 3,411 posts
Posted November 28, 2012 - 04:08 AM
That deck is for the pre-'72 generation. It hooks up a bit different then the later units. Its the same as the Jake Chiefs.
#17 KennyP ONLINE
  • 40,969 Thanks
  • 47,143 posts
Posted November 28, 2012 - 05:19 AM
Thanks, Keith! I'm too old to stand on my head to see pics.
If it is a pre- '72, then this (?) is the tractor manual. But it doesn't show the deck lift. Now to find the mower deck manual.
#18 Rodholderdepot OFFLINE
Rodholderdepot
  • 3 Thanks
  • 10 posts
Posted November 28, 2012 - 08:22 PM
The part I am looking for is a hook that goes into a slot on the lift arm for the mower deck or snow plow, it then has a loop at the bottom which goes over a stub on the mower frame and is kept in place with a large pin. I think I may be able to cobble one up with hardware from Tractor Supply, but i will keep looking. There is a good picture of in figure 25 in the 42 mower manual.
thanks
Edited by Rodholderdepot, November 28, 2012 - 08:26 PM.
#19 Rodholderdepot OFFLINE
Rodholderdepot
  • 3 Thanks
  • 10 posts
Posted December 02, 2012 - 12:21 PM
Hi Guys, Now I have my LGT 100 42 inch mower mounted but the PTO does not seem to engage, It is a manual pto and when i move it into the forward (on) position it slows the engine down a little but does not turn the belts to the mower. I check the belts an they appear to installed correctly, Any help is appreciated as always, drawings/manuals/ instructions etc.
THANKS
RODHOLDERDEPOT
#20 KennyP ONLINE
  • 40,969 Thanks
  • 47,143 posts
Posted December 03, 2012 - 06:02 AM
Look on page 14 of this manual. If this is your PTO clutch, I think I can find how to adjust it.
Edit: If that is the PTO clutch, this manual shows how to adjust it. Page 20 (22 in the adobe reader)
Edited by KennyP, December 03, 2012 - 06:09 AM.
Added comment
#21 Rodholderdepot OFFLINE
Rodholderdepot
  • 3 Thanks
  • 10 posts
Posted December 03, 2012 - 10:14 AM
Thanks, I see the PTO but I don't see the way to adjust it. When I start the tractor I can see the PTO shaft spinning but nothing happens when I engage it.
#22 Rodholderdepot OFFLINE
Rodholderdepot
  • 3 Thanks
  • 10 posts
Posted December 03, 2012 - 12:28 PM
Ok, it was a three day cage match but i emerged victorious thanks to your help. The mower is now mounted and working. The last issue appeared to be the PTO clutch was in need of adjustment. I tinkered with it and eventually got it right.
thanks,
Rodholderdepot
#23 KennyP ONLINE
  • 40,969 Thanks
  • 47,143 posts
Posted December 03, 2012 - 05:58 PM
Did the manuals I posted help any? I'm still trying to figure out which tractor this is. LOL
#24 UncleWillie OFFLINE
  • 16,260 Thanks
  • 8,975 posts
Posted December 03, 2012 - 07:40 PM
Congrats on your TKO.
#25 Rodholderdepot OFFLINE
Rodholderdepot
  • 3 Thanks
  • 10 posts
Posted December 06, 2012 - 07:34 AM
Yes, The manual helped, the picture diagrams in particular. Attached is a picture of the beast.
#26 KennyP ONLINE
  • 40,969 Thanks
  • 47,143 posts
Posted December 06, 2012 - 08:00 AM
Nice pic! Is that deck aluminum?
#27 Rodholderdepot OFFLINE
Rodholderdepot
  • 3 Thanks
  • 10 posts
Posted December 06, 2012 - 09:39 AM
Yes and aluminum deck, I got it last week and after freeing up the wheel adjusters and reinstalling the belt it works good.
#28 UncleWillie OFFLINE
  • 16,260 Thanks
  • 8,975 posts
Posted December 06, 2012 - 11:37 AM
That is a good looking old Ford.
#29 KennyP ONLINE
  • 40,969 Thanks
  • 47,143 posts
Posted December 06, 2012 - 06:43 PM
At least you don't have to worry about the deck rusting! Glad you got it all figured out.
#30 HankS OFFLINE
HankS
  • 48 Thanks
  • 107 posts
Posted December 09, 2012 - 09:07 AM
The tractor is a Ford 100, 10hp, from the late 60's. They also made a Ford 80, 8hp, and 120, 12hp. Made by Jacobsen and same as the Jacobsen Chiefs. The LGT models came after these and are tube frame tractors. Just a little info so you know when looking for parts or help.
Here is a link about the Jacobsen gauge used to adjust the manual PTO.
http://gardentractor...o-clutch-gauge/
If the PTO clutch wants to keep turning when disengaged, take it apart and clean the clutch disc and both pulley surfaces. I had that problem on a Ford 120. Lot's of grease and dirt build up on the clutch plates.
Nice looking tractor, consider that it's over 40 years old.
Edited by HankS, December 09, 2012 - 09:09 AM.
