Ss15 Fuel Pump?
4 replies to this topic
#1 Brando OFFLINE
Brando
  • 339 Thanks
  • 331 posts
Posted November 26, 2012 - 07:52 PM
Can I hook up the gas line straight to the carb and bypass the fuel pump. Mine was missing when I bought the tractor.
#2 MH81 OFFLINE
Posted November 26, 2012 - 09:27 PM
As long as the tank is above the inlet on the carb, it should be OK, but It may start to lean up or run out of gas when the tank is low or the tractor is running uphill.
There are a couple threads here about reasonable aftermarket low psi electric pumps. I'll look a little later for them.
#3 tinbender7 OFFLINE
tinbender7
  • 1,115 Thanks
  • 784 posts
Posted November 26, 2012 - 10:15 PM
I am running a Ford 100 that way.
#4 MH81 OFFLINE
Posted November 26, 2012 - 10:24 PM
Here is the pump that Ducky and Daniel have used with good success in the past:
http://mr-gasket.com...pump-42gph.html
If you look at a different one, make sure it's a low pressure (2ish psi)
#5 Brando OFFLINE
Brando
  • 339 Thanks
  • 331 posts
Posted November 30, 2012 - 11:23 PM
Thanks, I found an original pump for 30 on eBay. I might just end up going aftermarket.
