Coupler
11 replies to this topic
#1 larryd OFFLINE
larryd
  • 724 Thanks
  • 1,058 posts
Posted November 26, 2012 - 09:07 AM
Does anyone know where I might find a rear driveshaft coupler for a jd 314?
Also does this use a pin or a bolt? Hole is quite elongated in coupler for pin. Hydro shaft seeems to be ok but coupler loose on shaft. Service manuals or downloads seem to be scarce for a jd .314
I am new to this sight and this type of problem on my tractor. Any help appreciated.
Thanks
larryd
#2 bhts OFFLINE
bhts
  • 1,476 Thanks
  • 2,169 posts
Posted November 26, 2012 - 09:15 AM
The driveshaft uses a spring pin or groove pin to hold it to the hydro pump. I will take a look and see if i have one here.
#3 larryd OFFLINE
larryd
  • 724 Thanks
  • 1,058 posts
Posted November 26, 2012 - 09:49 AM
thanks BHTS. If I knew the size I might could find one at fastenal.
larryd
#4 bhts OFFLINE
bhts
  • 1,476 Thanks
  • 2,169 posts
Posted November 26, 2012 - 09:52 AM
I belive it was a 1/4 inch pin around 1 1/2 - 2 inches long.
#5 Deere Green OFFLINE
Deere Green
  • 24 Thanks
  • 126 posts
Posted November 26, 2012 - 09:54 AM
going through the same issue with my 317 currently. good luck
#6 SonnyT OFFLINE
SonnyT
    Deceased
  • 116 Thanks
  • 125 posts
Posted November 26, 2012 - 09:56 AM
from JDparts.com under your 314 parts. /images/clear.gif
Part Details /images/clear.gif Part Number: /images/clear.gif M81896 Replaces Part: M83141 Part Price: 1.29 USD On Hand: ../images/clear.gif 0 Check Other Stores Description: PIN, SPIRAL .25X1.5 - PUR
#7 SonnyT OFFLINE
SonnyT
    Deceased
  • 116 Thanks
  • 125 posts
Posted November 26, 2012 - 10:01 AM
Our 317's has a different driveshaft I believe. At least mine looks different than the one I just looked up for the 314.
#8 Deere Green OFFLINE
Deere Green
  • 24 Thanks
  • 126 posts
Posted November 26, 2012 - 10:14 AM
they are different i was just shooting out a "good luck". pulling the engine is never a fun fleet. rebuilt mine a year or so ago and think pulling the thing was the worst part of the deal.
#9 timtractor OFFLINE
timtractor
  • 224 Thanks
  • 376 posts
Posted November 26, 2012 - 10:22 AM
Go to your local John Deere dealer. Those parts are still available. Couplers look to be from $25 to $30 dollars each.
#10 SonnyT OFFLINE
SonnyT
    Deceased
  • 116 Thanks
  • 125 posts
Posted November 26, 2012 - 10:29 AM
also the 317 grooved pin is a different number---m81896
sorry, I will butt out now.
Edited by SonnyT, November 26, 2012 - 10:30 AM.
#11 ol' stonebreaker OFFLINE
ol' stonebreaker
  • Validating
  • 1,690 Thanks
  • 1,148 posts
Posted November 26, 2012 - 10:51 AM
I believe Joe's outdoor power has some couplers on ebay. Can't remember if for a 314 or 317.
Mike
#12 JDBrian OFFLINE
  • 9,646 Thanks
  • 14,158 posts
Posted November 26, 2012 - 11:23 AM
If you check on JDParts.com and enter 314 in the model search you can see the parts diagrams and get part numbers. The new couplers use a conical tipped set screw. The original uses a pin. The 317 uses a drive shaft with u joints and is a different beast entirely.
